1 - 3 of 3 Posts
got about $850 AUD, looking at buying 1070 Ti everyone says 1080 i think? currently got 670 and getting 99c and 100fps on low details csgo 300 solid and 68c tho kinda wanna play at native resolution for once
Sounds horrid with those temps and noise :/
As for cards, I recommend the MSI Gaming, Asus Strix or EVGA FTW. All of them good choices with decent cooling and OC cabability. There are also others with good setups, recommend you read some reviews and look at the PCB's, cooling solutions, and OC results.
Good luck :)
I second the Asus ROG Strix line(triple fan models). Up until 50 or so degrees the fans do not spin up so less noise and wear on the fans.
1 - 3 of 3 Posts
