It maybe someone elses mic. It usally does that to me on xbox live but I havent had any pc problems like that.
Just checking, are you sure your not going crazy?
Hmm i dont have the headset myself, but it sounds to me if you had to install software for it maybe the "Listen to this device" is checked on in the software.Originally Posted by madbadburt
HI there - I bought one of these headsets last week - I mostly use it for teamspeak on the PC... i too encountered the "hearing myself" issue... i did find the box to tick to not listen to myself talking the whole time... but it wasn't ticked!! - I ticked it, hit apply, then unticked it again & hey presto - problem fixed.... or so I thought...
Problem is... if I unplug the usb connection, reboot the PC (WIN-7 Ultimate x64) and then plug the headset's USB adaptor back in, the settings revert to to hearing myself (again... the box in Control Panel -> Sound -> Recording Tab is again not ticked, but self listen is active!!
when I check the box & hit apply, i hear myself but with a fraction of a second delay.... VERY off-putting indeed!! then when I un-check the box & apply, its fine...
my issue seems to be repeatable... every time I reboot & then plug the headset, the fold-back or "listen" gets turned on, without the box being checked.
has anyone else had this issue, and resolved it?? or do I send the headset back a PoS? as it is really beginning to upset me that after spending what I consider to be a lot of money, the flipping thing doesn't perform as it should![]()
i look forward to hearing from anyone that has a suggestion.
Thanks
Burt
