Originally Posted by SlyFox
Upping the voltages on your vdimms will not help you overclock your cpu. Ericeod recommended up the vCore to 1.5 and your NB to 1.3v. This should allow you to attain the oc your looking for. Run stress tests and check temps, etc.
I ammeded my first post about the NB voltage. I adjusted it for the 780i NB. I did not recommend 1.5v vcore, that is going to kill a 45nm CPU.
Do not go over 1.3625v vcore to the CPU. The 1.5v is for the 780i NB max voltage. I recommend
1.35v to the NB for a 400 FSB OC with a quad core.
Here is NVIDIA's overclocker's guide. This manual is a must read!
NVIDIA 780i/680i Overclocker's Guide, revised May 2008
Note that this guide is for the reference NVIDIA design which ASUS doesnt follow. So the terms are different. To clarify, SPP is the northbridge and the MCP is the southbridge...
