1 - 6 of 6 Posts
That I have been running my memory at 7-7-7-20-78 1T at 1530mhz with 1.60v and it's stable through prime blend
. Never noticed until a month after I ran prime when I went into the bios and noticed that my vdimm voltage was 1.60v
. You think it's safe to run it like this?
*cough*Stock*cough*
Running ram at 1.6v when it's spec'd @ 1.65v is fine. It saves power, and helps with less heat produced from your modules.
Iconoclast
Originally Posted by Willanhanyard View Post
Yeah, but I have it at 1.60v instead of 1.65v. I guess thats not very good
Less voltage is always better, as long as you are stable.
Don't up voltage unless you need to.
1 - 6 of 6 Posts
