No clue what is causing this, so I also got no clue what I need to modify to keep this from happening again? I can't really take a SC of my bios settings because I'm on a Gigabyte board.
I didn't run a 24 hour test, but I ran a 7 hour test + a 2 hour burn test, and no crash. Also played skyrim for 2 hours at max settings, and also Crysis 3 on high, no crash. Using my PC normally when it wasn't even under that much load, then it crashes. Last time it crashed it was as I hit the X to close a window.
My voltage is 1.356v for 4.6ghz.
I've been trying for almost a week and I can't find a stable OC that is 4.5ghz or higher.
Also my rig won't even boot with x45 multiplier, no matter what the voltage is. Someone care to explain that? Same voltage, x45 multiplier, doesn't boot. Bump it to 4.6ghz then it boots, but isn't stable.
I got these disabled:
C1E
EIST
C3, C6 states
CPU_Thermal monitor disabled
Other settings:
Multi step load line = level 7
Vcore = 1.31v
Turbo Disabled
Something here that could be causing the problem?
C1E
EIST
C3, C6 states
Other settings:
Vcore = 1.31v
Turbo Disabled
