1 - 15 of 15 Posts
My overclock is perfectly stable but if I never pause the client the WU dies and it comes up with this. WARNING:FS01:Killing WU01
It just started happening since this new install of Windows.
RAM is 24 hours stable through memtest86+ each stick.
CPU is stable 24 hours of PRIME95 and I did 48 hours straight of [email protected] before I paused the client.
Originally Posted by mmonnin View Post
Should post a log
Here you go:
*********************** Log Started 2013-02-14T21:09:41Z ***********************
21:09:41:************************* [email protected] Client *************************
21:09:41:      Website: http://folding.stanford.edu/
21:09:41:    Copyright: (c) 2009-2012 Stanford University
21:09:41:       Author: Joseph Coffland <[email protected]>
21:09:41:         Args: --lifeline 536 --command-port=36330
21:09:41:       Config: E:/Backups/FAHClient/config.xml
21:09:41:******************************** Build ********************************
21:09:41:      Version: 7.1.52
21:09:41:         Date: Mar 20 2012
21:09:41:         Time: 19:37:42
21:09:41:      SVN Rev: 3515
21:09:41:       Branch: fah/trunk/client
21:09:41:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:09:41:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:09:41:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
21:09:41:     Platform: win32 XP
21:09:41:         Bits: 32
21:09:41:         Mode: Release
21:09:41:******************************* System ********************************
21:09:41:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
21:09:41:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:09:41:         CPUs: 8
21:09:41:       Memory: 7.88GiB
21:09:41:  Free Memory: 6.50GiB
21:09:41:      Threads: WINDOWS_THREADS
21:09:41:   On Battery: false
21:09:41:   UTC offset: -5
21:09:41:          PID: 2200
21:09:41:          CWD: E:/Backups/FAHClient
21:09:41:           OS: Windows 7 Home Premium
21:09:41:      OS Arch: AMD64
21:09:41:         GPUs: 1
21:09:41:        GPU 0: ATI:4 Cypress [Radeon HD 5800 Series]
21:09:41:         CUDA: Not detected
21:09:41:Win32 Service: false
21:09:41:***********************************************************************
21:09:41:<config>
21:09:41:  <!-- Network -->
21:09:41:  <proxy v=':8080'/>
21:09:41:
21:09:41:  <!-- Remote Command Server -->
21:09:41:  <password v=''/>
21:09:41:
21:09:41:  <!-- User Information -->
21:09:41:  <passkey v='********************************'/>
21:09:41:  <team v='37726'/>
21:09:41:  <user v='William_Adam'/>
21:09:41:
21:09:41:  <!-- Folding Slots -->
21:09:41:  <slot id='1' type='SMP'/>
21:09:41:</config>
21:09:41:Trying to access database...
21:09:41:Successfully acquired database lock
21:09:41:Enabled folding slot 01: READY smp:8
21:09:41:WU00:FS01:Starting
21:09:41:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
21:09:41:WU00:FS01:Started FahCore on PID 2672
21:09:42:WU00:FS01:Core PID:2760
21:09:42:WU00:FS01:FahCore 0xa4 started
21:09:42:WU00:FS01:0xa4:
21:09:42:WU00:FS01:0xa4:*------------------------------*
21:09:42:WU00:FS01:0xa4:[email protected] Gromacs GB Core
21:09:42:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:09:42:WU00:FS01:0xa4:Preparing to commence simulation
21:09:42:WU00:FS01:0xa4:- Looking at optimizations...
21:09:42:WU00:FS01:0xa4:- Files status OK
21:09:42:WU00:FS01:0xa4:- Expanded 547534 -> 844760 (decompressed 154.2 percent)
21:09:42:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547534 data_size=844760, decompressed_data_size=844760 diff=0
21:09:42:WU00:FS01:0xa4:- Digital signature verified
21:09:42:WU00:FS01:0xa4:Project: 7646 (Run 104, Clone 3, Gen 69)
21:09:42:WU00:FS01:0xa4:Assembly optimizations on if available.
21:09:42:WU00:FS01:0xa4:Entering M.D.
21:09:42:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
21:09:48:WU00:FS01:0xa4:Using Gromacs checkpoints
21:09:48:WU00:FS01:0xa4:Mapping NT from 8 to 8
21:09:49:WU00:FS01:0xa4:Resuming from checkpoint
21:09:49:WU00:FS01:0xa4:Verified 00/wudata_01.log
21:09:50:WU00:FS01:0xa4:Verified 00/wudata_01.trr
21:09:50:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
21:09:50:WU00:FS01:0xa4:Verified 00/wudata_01.edr
21:09:50:WU00:FS01:0xa4:Completed 1635600 out of 2500000 steps  (65%)
21:19:12:WU00:FS01:0xa4:Completed 1650000 out of 2500000 steps  (66%)
21:32:14:WU00:FS01:0xa4:Completed 1675000 out of 2500000 steps  (67%)
21:45:19:WU00:FS01:0xa4:Completed 1700000 out of 2500000 steps  (68%)
21:58:19:WU00:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
22:11:22:WU00:FS01:0xa4:Completed 1750000 out of 2500000 steps  (70%)
22:24:22:WU00:FS01:0xa4:Completed 1775000 out of 2500000 steps  (71%)
22:37:28:WU00:FS01:0xa4:Completed 1800000 out of 2500000 steps  (72%)
22:50:29:WU00:FS01:0xa4:Completed 1825000 out of 2500000 steps  (73%)
23:03:28:WU00:FS01:0xa4:Completed 1850000 out of 2500000 steps  (74%)
23:16:27:WU00:FS01:0xa4:Completed 1875000 out of 2500000 steps  (75%)
23:29:32:WU00:FS01:0xa4:Completed 1900000 out of 2500000 steps  (76%)
23:42:34:WU00:FS01:0xa4:Completed 1925000 out of 2500000 steps  (77%)
23:55:32:WU00:FS01:0xa4:Completed 1950000 out of 2500000 steps  (78%)
00:08:33:WU00:FS01:0xa4:Completed 1975000 out of 2500000 steps  (79%)
00:21:34:WU00:FS01:0xa4:Completed 2000000 out of 2500000 steps  (80%)
00:36:21:WU00:FS01:0xa4:Completed 2025000 out of 2500000 steps  (81%)
00:40:41:FS01:Paused
00:40:42:FS01:Shutting core down
00:40:51:WU00:FS01:0xa4:Client no longer detected. Shutting down core
00:40:51:WU00:FS01:0xa4:[email protected] Core Shutdown: CLIENT_DIED
00:41:43:WARNING:FS01:Killing WU00
00:41:43:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
******************************** Date: 15/02/13 ********************************
07:58:47:FS01:Unpaused
07:58:47:WU00:FS01:Starting
07:58:47:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
07:58:47:WU00:FS01:Started FahCore on PID 5332
07:58:47:WU00:FS01:Core PID:5912
07:58:47:WU00:FS01:FahCore 0xa4 started
07:58:48:WU00:FS01:0xa4:
07:58:48:WU00:FS01:0xa4:*------------------------------*
07:58:48:WU00:FS01:0xa4:[email protected] Gromacs GB Core
07:58:48:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
07:58:48:WU00:FS01:0xa4:Preparing to commence simulation
07:58:48:WU00:FS01:0xa4:- Looking at optimizations...
07:58:48:WU00:FS01:0xa4:- Files status OK
07:58:48:WU00:FS01:0xa4:- Expanded 547534 -> 844760 (decompressed 154.2 percent)
07:58:48:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547534 data_size=844760, decompressed_data_size=844760 diff=0
07:58:48:WU00:FS01:0xa4:- Digital signature verified
07:58:48:WU00:FS01:0xa4:Project: 7646 (Run 104, Clone 3, Gen 69)
07:58:48:WU00:FS01:0xa4:Assembly optimizations on if available.
07:58:48:WU00:FS01:0xa4:Entering M.D.
07:58:53:WU00:FS01:0xa4:Using Gromacs checkpoints
07:58:54:WU00:FS01:0xa4:Mapping NT from 8 to 8
07:58:54:WU00:FS01:0xa4:Resuming from checkpoint
07:58:54:WU00:FS01:0xa4:Verified 00/wudata_01.log
07:58:56:WU00:FS01:0xa4:Verified 00/wudata_01.trr
07:58:56:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
07:58:56:WU00:FS01:0xa4:Verified 00/wudata_01.edr
07:58:56:WU00:FS01:0xa4:Completed 2031010 out of 2500000 steps  (81%)
08:10:13:WU00:FS01:0xa4:Completed 2050000 out of 2500000 steps  (82%)
08:24:31:WU00:FS01:0xa4:Completed 2075000 out of 2500000 steps  (83%)
08:29:47:FS01:Paused
08:29:47:FS01:Shutting core down
08:29:50:WU00:FS01:0xa4:Client no longer detected. Shutting down core
08:29:50:WU00:FS01:0xa4:[email protected] Core Shutdown: CLIENT_DIED
08:29:50:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
08:58:30:FS01:Unpaused
08:58:30:WU00:FS01:Starting
08:58:30:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
08:58:30:WU00:FS01:Started FahCore on PID 6092
08:58:30:WU00:FS01:Core PID:2624
08:58:30:WU00:FS01:FahCore 0xa4 started
08:58:31:WU00:FS01:0xa4:
08:58:31:WU00:FS01:0xa4:*------------------------------*
08:58:31:WU00:FS01:0xa4:[email protected] Gromacs GB Core
08:58:31:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
08:58:31:WU00:FS01:0xa4:Preparing to commence simulation
08:58:31:WU00:FS01:0xa4:- Looking at optimizations...
08:58:31:WU00:FS01:0xa4:- Files status OK
08:58:31:WU00:FS01:0xa4:- Expanded 547534 -> 844760 (decompressed 154.2 percent)
08:58:31:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547534 data_size=844760, decompressed_data_size=844760 diff=0
08:58:31:WU00:FS01:0xa4:- Digital signature verified
08:58:31:WU00:FS01:0xa4:Project: 7646 (Run 104, Clone 3, Gen 69)
08:58:31:WU00:FS01:0xa4:Assembly optimizations on if available.
08:58:31:WU00:FS01:0xa4:Entering M.D.
08:58:36:WU00:FS01:0xa4:Using Gromacs checkpoints
08:58:37:WU00:FS01:0xa4:Mapping NT from 8 to 8
08:58:37:WU00:FS01:0xa4:Resuming from checkpoint
08:58:37:WU00:FS01:0xa4:Verified 00/wudata_01.log
08:58:38:WU00:FS01:0xa4:Verified 00/wudata_01.trr
08:58:39:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
08:58:39:WU00:FS01:0xa4:Verified 00/wudata_01.edr
08:58:39:WU00:FS01:0xa4:Completed 2082750 out of 2500000 steps  (83%)
09:08:50:WU00:FS01:0xa4:Completed 2100000 out of 2500000 steps  (84%)
09:23:16:WU00:FS01:0xa4:Completed 2125000 out of 2500000 steps  (85%)
09:36:24:WU00:FS01:0xa4:Completed 2150000 out of 2500000 steps  (86%)
09:49:54:WU00:FS01:0xa4:Completed 2175000 out of 2500000 steps  (87%)
10:02:58:WU00:FS01:0xa4:Completed 2200000 out of 2500000 steps  (88%)
10:16:05:WU00:FS01:0xa4:Completed 2225000 out of 2500000 steps  (89%)
10:29:08:WU00:FS01:0xa4:Completed 2250000 out of 2500000 steps  (90%)
10:42:18:WU00:FS01:0xa4:Completed 2275000 out of 2500000 steps  (91%)
10:55:33:WU00:FS01:0xa4:Completed 2300000 out of 2500000 steps  (92%)
11:08:42:WU00:FS01:0xa4:Completed 2325000 out of 2500000 steps  (93%)
11:21:45:WU00:FS01:0xa4:Completed 2350000 out of 2500000 steps  (94%)
11:34:51:WU00:FS01:0xa4:Completed 2375000 out of 2500000 steps  (95%)
11:48:07:WU00:FS01:0xa4:Completed 2400000 out of 2500000 steps  (96%)
12:01:16:WU00:FS01:0xa4:Completed 2425000 out of 2500000 steps  (97%)
12:14:26:WU00:FS01:0xa4:Completed 2450000 out of 2500000 steps  (98%)
12:27:38:WU00:FS01:0xa4:Completed 2475000 out of 2500000 steps  (99%)
12:27:39:WU01:FS01:Connecting to assign3.stanford.edu:8080
12:27:39:WU01:FS01:News: Welcome to [email protected]
12:27:39:WU01:FS01:Assigned to work server 171.67.108.60
12:27:39:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
12:27:39:WU01:FS01:Connecting to 171.67.108.60:8080
12:27:41:WU01:FS01:Downloading 513.12KiB
12:27:41:WU01:FS01:Download complete
12:27:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8028 run:154 clone:2 gen:65 core:0xa4 unit:0x000000656652edcc50e78efc79472307
12:40:48:WU00:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
12:40:48:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:40:58:WU00:FS01:0xa4:
12:40:58:WU00:FS01:0xa4:Finished Work Unit:
12:40:58:WU00:FS01:0xa4:- Reading up to 13394784 from "00/wudata_01.trr": Read 13394784
12:40:58:WU00:FS01:0xa4:trr file hash check passed.
12:40:58:WU00:FS01:0xa4:- Reading up to 1986888 from "00/wudata_01.xtc": Read 1986888
12:40:58:WU00:FS01:0xa4:xtc file hash check passed.
12:40:58:WU00:FS01:0xa4:edr file hash check passed.
12:40:58:WU00:FS01:0xa4:logfile size: 46514
12:40:58:WU00:FS01:0xa4:Leaving Run
12:41:01:WU00:FS01:0xa4:- Writing 15443350 bytes of core data to disk...
12:41:03:WU00:FS01:0xa4:Done: 15442838 -> 14712601 (compressed to 95.2 percent)
12:41:03:WU00:FS01:0xa4:  ... Done.
12:41:05:WU00:FS01:0xa4:- Shutting down core
12:41:05:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
12:41:05:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:41:06:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:7646 run:104 clone:3 gen:69 core:0xa4 unit:0x00000064664f2dcd4fa7fe20d0ee3714
12:41:06:WU00:FS01:Uploading 14.03MiB to 171.64.65.101
12:41:06:WU01:FS01:Starting
12:41:06:WU00:FS01:Connecting to 171.64.65.101:8080
12:41:06:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
12:41:06:WU01:FS01:Started FahCore on PID 5916
12:41:06:WU01:FS01:Core PID:5100
12:41:06:WU01:FS01:FahCore 0xa4 started
12:41:07:WU01:FS01:0xa4:
12:41:07:WU01:FS01:0xa4:*------------------------------*
12:41:07:WU01:FS01:0xa4:[email protected] Gromacs GB Core
12:41:07:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:41:07:WU01:FS01:0xa4:Preparing to commence simulation
12:41:07:WU01:FS01:0xa4:- Looking at optimizations...
12:41:07:WU01:FS01:0xa4:- Created dyn
12:41:07:WU01:FS01:0xa4:- Files status OK
12:41:07:WU01:FS01:0xa4:- Expanded 524919 -> 1190336 (decompressed 226.7 percent)
12:41:07:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=524919 data_size=1190336, decompressed_data_size=1190336 diff=0
12:41:07:WU01:FS01:0xa4:- Digital signature verified
12:41:07:WU01:FS01:0xa4:Project: 8028 (Run 154, Clone 2, Gen 65)
12:41:07:WU01:FS01:0xa4:Assembly optimizations on if available.
12:41:07:WU01:FS01:0xa4:Entering M.D.
12:41:12:WU00:FS01:Upload 6.24%
12:41:12:WU01:FS01:0xa4:Mapping NT from 8 to 8
12:41:13:WU01:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
12:41:18:WU00:FS01:Upload 11.14%
12:41:24:WU00:FS01:Upload 16.48%
12:41:30:WU00:FS01:Upload 21.38%
12:41:36:WU00:FS01:Upload 26.28%
12:41:42:WU00:FS01:Upload 31.63%
12:41:48:WU00:FS01:Upload 36.52%
12:41:54:WU00:FS01:Upload 41.42%
12:42:00:WU00:FS01:Upload 46.32%
12:42:06:WU00:FS01:Upload 51.67%
12:42:12:WU00:FS01:Upload 56.57%
12:42:15:WU01:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
12:42:18:WU00:FS01:Upload 61.47%
12:42:24:WU00:FS01:Upload 66.37%
12:42:30:WU00:FS01:Upload 71.27%
12:42:36:WU00:FS01:Upload 76.61%
12:42:42:WU00:FS01:Upload 81.51%
12:42:48:WU00:FS01:Upload 86.41%
12:42:54:WU00:FS01:Upload 91.31%
12:43:00:WU00:FS01:Upload 96.21%
12:43:06:WU00:FS01:Upload complete
12:43:06:WU00:FS01:Server responded WORK_ACK (400)
12:43:06:WU00:FS01:Final credit estimate, 14707.00 points
12:43:06:WU00:FS01:Cleaning up
12:43:18:WU01:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
12:44:22:WU01:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
12:45:28:WU01:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
12:46:29:WU01:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
12:47:31:WU01:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
12:48:34:WU01:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
12:49:34:WU01:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
12:50:37:WU01:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
12:51:37:WU01:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
12:52:39:WU01:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
12:53:40:WU01:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
12:54:41:WU01:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
12:55:43:WU01:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
12:56:44:WU01:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
12:57:44:WU01:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
12:58:47:WU01:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
12:59:48:WU01:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
13:00:48:WU01:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
13:01:51:WU01:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
13:02:54:WU01:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
13:03:54:WU01:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
13:04:57:WU01:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
13:05:57:WU01:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
13:07:00:WU01:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
13:08:01:WU01:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
13:09:04:WU01:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
13:10:06:WU01:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
13:11:07:WU01:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
13:12:09:WU01:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
13:13:10:WU01:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
13:14:13:WU01:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
13:15:15:WU01:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
13:16:18:WU01:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
13:17:18:WU01:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
13:18:19:WU01:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
13:19:22:WU01:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
13:20:24:WU01:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
13:21:26:WU01:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
13:22:28:WU01:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
13:23:29:WU01:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
13:24:30:WU01:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
13:25:32:WU01:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
13:26:33:WU01:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
13:27:35:WU01:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
13:28:36:WU01:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
13:29:39:WU01:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
13:30:39:WU01:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
13:31:40:WU01:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
13:32:42:WU01:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
13:33:44:WU01:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
13:34:47:WU01:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
13:35:48:WU01:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
13:36:50:WU01:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
13:37:51:WU01:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
13:38:53:WU01:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
13:39:53:WU01:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
13:40:54:WU01:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
13:41:57:WU01:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
13:42:57:WU01:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
13:43:59:WU01:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
13:45:11:WU01:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
13:46:11:WU01:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
13:47:13:WU01:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
13:48:14:WU01:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
13:49:16:WU01:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
13:50:16:WU01:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
13:51:19:WU01:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
13:52:22:WU01:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
13:53:22:WU01:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
13:54:23:WU01:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
13:55:25:WU01:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
13:56:26:WU01:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
13:57:27:WU01:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
13:58:30:WU01:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
13:59:31:WU01:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
14:00:34:WU01:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
14:01:34:WU01:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
14:02:37:WU01:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
14:03:38:WU01:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
14:04:41:WU01:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
14:05:42:WU01:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
14:06:44:WU01:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
14:07:45:WU01:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
14:08:48:WU01:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
14:09:48:WU01:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
14:10:51:WU01:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
14:11:52:WU01:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
14:12:53:WU01:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
14:13:56:WU01:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
14:14:59:WU01:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
14:16:00:WU01:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
14:17:01:WU01:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
14:18:03:WU01:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
14:19:04:WU01:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
14:20:06:WU01:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
14:21:07:WU01:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
14:22:10:WU01:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
14:23:11:WU01:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
14:23:11:WU00:FS01:Connecting to assign3.stanford.edu:8080
14:23:11:WU00:FS01:News: Welcome to [email protected]
14:23:11:WU00:FS01:Assigned to work server 171.67.108.60
14:23:11:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
14:23:11:WU00:FS01:Connecting to 171.67.108.60:8080
14:23:13:WU00:FS01:Downloading 512.97KiB
14:23:13:WU00:FS01:Download complete
14:23:13:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8028 run:2170 clone:0 gen:53 core:0xa4 unit:0x000000656652edcc50e7966d69d2487a
14:24:13:WU01:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
14:24:13:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:24:23:WU01:FS01:0xa4:
14:24:23:WU01:FS01:0xa4:Finished Work Unit:
14:24:23:WU01:FS01:0xa4:- Reading up to 770640 from "01/wudata_01.trr": Read 770640
14:24:23:WU01:FS01:0xa4:trr file hash check passed.
14:24:23:WU01:FS01:0xa4:- Reading up to 836896 from "01/wudata_01.xtc": Read 836896
14:24:23:WU01:FS01:0xa4:xtc file hash check passed.
14:24:23:WU01:FS01:0xa4:edr file hash check passed.
14:24:23:WU01:FS01:0xa4:logfile size: 26343
14:24:23:WU01:FS01:0xa4:Leaving Run
14:24:25:WU01:FS01:0xa4:- Writing 1642703 bytes of core data to disk...
14:24:25:WU01:FS01:0xa4:Done: 1642191 -> 1580664 (compressed to 96.2 percent)
14:24:25:WU01:FS01:0xa4:  ... Done.
14:24:25:WU01:FS01:0xa4:- Shutting down core
14:24:26:WU01:FS01:0xa4:
14:24:26:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
14:24:26:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:24:26:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8028 run:154 clone:2 gen:65 core:0xa4 unit:0x000000656652edcc50e78efc79472307
14:24:26:WU01:FS01:Uploading 1.51MiB to 171.67.108.60
14:24:26:WU00:FS01:Starting
14:24:26:WU01:FS01:Connecting to 171.67.108.60:8080
14:24:26:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
14:24:26:WU00:FS01:Started FahCore on PID 4992
14:24:26:WU00:FS01:Core PID:5460
14:24:26:WU00:FS01:FahCore 0xa4 started
14:24:27:WU00:FS01:0xa4:
14:24:27:WU00:FS01:0xa4:*------------------------------*
14:24:27:WU00:FS01:0xa4:[email protected] Gromacs GB Core
14:24:27:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
14:24:27:WU00:FS01:0xa4:Preparing to commence simulation
14:24:27:WU00:FS01:0xa4:- Looking at optimizations...
14:24:27:WU00:FS01:0xa4:- Created dyn
14:24:27:WU00:FS01:0xa4:- Files status OK
14:24:27:WU00:FS01:0xa4:- Expanded 524765 -> 1189616 (decompressed 226.6 percent)
14:24:27:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=524765 data_size=1189616, decompressed_data_size=1189616 diff=0
14:24:27:WU00:FS01:0xa4:- Digital signature verified
14:24:27:WU00:FS01:0xa4:Project: 8028 (Run 2170, Clone 0, Gen 53)
14:24:27:WU00:FS01:0xa4:Assembly optimizations on if available.
14:24:27:WU00:FS01:0xa4:Entering M.D.
14:24:32:WU00:FS01:0xa4:Mapping NT from 8 to 8
14:24:32:WU00:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
14:24:37:WU01:FS01:Upload complete
14:24:37:WU01:FS01:Server responded WORK_ACK (400)
14:24:37:WU01:FS01:Final credit estimate, 1958.00 points
14:24:37:WU01:FS01:Cleaning up
14:25:33:WU00:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
14:26:36:WU00:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
14:27:38:WU00:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
14:28:39:WU00:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
14:29:42:WU00:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
14:30:42:WU00:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
14:31:45:WU00:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
14:32:46:WU00:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
14:33:48:WU00:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
14:34:49:WU00:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
14:35:52:WU00:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
14:36:55:WU00:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
14:37:55:WU00:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
14:38:58:WU00:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
14:39:59:WU00:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
14:41:01:WU00:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
14:42:02:WU00:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
14:43:02:WU00:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
14:44:05:WU00:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
14:45:16:WU00:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
14:46:16:WU00:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
14:47:19:WU00:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
14:48:19:WU00:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
14:49:22:WU00:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
14:50:26:WU00:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
14:51:28:WU00:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
14:52:30:WU00:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
14:53:32:WU00:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
14:54:33:WU00:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
14:55:36:WU00:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
14:56:37:WU00:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
14:57:39:WU00:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
14:58:40:WU00:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
14:59:42:WU00:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
15:00:44:WU00:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
15:01:45:WU00:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
15:02:45:WU00:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
15:03:48:WU00:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
15:04:49:WU00:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
15:05:51:WU00:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
15:06:51:WU00:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
15:07:54:WU00:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
15:08:55:WU00:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
15:09:58:WU00:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
15:10:58:WU00:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
15:12:01:WU00:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
15:13:01:WU00:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
15:14:04:WU00:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
15:15:04:WU00:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
15:16:07:WU00:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
15:17:08:WU00:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
15:18:10:WU00:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
15:19:10:WU00:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
15:20:13:WU00:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
15:21:13:WU00:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
15:22:16:WU00:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
15:23:16:WU00:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
15:24:19:WU00:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
15:25:19:WU00:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
15:26:22:WU00:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
15:27:24:WU00:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
15:28:24:WU00:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
15:29:27:WU00:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
15:30:27:WU00:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
15:31:28:WU00:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
15:32:30:WU00:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
15:33:31:WU00:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
15:34:31:WU00:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
15:35:34:WU00:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
15:36:34:WU00:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
15:37:37:WU00:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
15:38:37:WU00:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
15:39:39:WU00:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
15:40:41:WU00:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
15:41:42:WU00:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
15:42:44:WU00:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
15:43:45:WU00:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
15:44:55:WU00:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
15:45:56:WU00:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
15:46:57:WU00:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
15:47:59:WU00:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
15:49:02:WU00:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
15:50:03:WU00:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
15:51:04:WU00:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
15:52:06:WU00:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
15:53:08:WU00:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
15:54:09:WU00:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
15:55:12:WU00:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
15:56:13:WU00:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
15:57:15:WU00:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
15:58:16:WU00:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
15:59:20:WU00:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
16:00:20:WU00:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
16:01:23:WU00:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
16:02:26:WU00:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
16:03:26:WU00:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
16:04:27:WU00:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
16:05:30:WU00:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
16:06:32:WU00:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
16:06:33:WU01:FS01:Connecting to assign3.stanford.edu:8080
16:06:33:WU01:FS01:News: Welcome to [email protected]
16:06:33:WU01:FS01:Assigned to work server 171.67.108.60
16:06:33:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
16:06:33:WU01:FS01:Connecting to 171.67.108.60:8080
16:06:35:WU01:FS01:Downloading 513.42KiB
16:06:35:WU01:FS01:Download complete
16:06:35:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8028 run:495 clone:0 gen:79 core:0xa4 unit:0x000000846652edcc50e7903e6b028740
16:07:35:WU00:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
16:07:35:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
16:07:45:WU00:FS01:0xa4:
16:07:45:WU00:FS01:0xa4:Finished Work Unit:
16:07:45:WU00:FS01:0xa4:- Reading up to 770100 from "00/wudata_01.trr": Read 770100
16:07:45:WU00:FS01:0xa4:trr file hash check passed.
16:07:45:WU00:FS01:0xa4:- Reading up to 836092 from "00/wudata_01.xtc": Read 836092
16:07:45:WU00:FS01:0xa4:xtc file hash check passed.
16:07:45:WU00:FS01:0xa4:edr file hash check passed.
16:07:45:WU00:FS01:0xa4:logfile size: 26340
16:07:45:WU00:FS01:0xa4:Leaving Run
16:07:50:WU00:FS01:0xa4:- Writing 1641356 bytes of core data to disk...
16:07:50:WU00:FS01:0xa4:Done: 1640844 -> 1579375 (compressed to 96.2 percent)
16:07:50:WU00:FS01:0xa4:  ... Done.
16:07:51:WU00:FS01:0xa4:- Shutting down core
16:07:51:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
16:07:51:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:07:51:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8028 run:2170 clone:0 gen:53 core:0xa4 unit:0x000000656652edcc50e7966d69d2487a
16:07:51:WU00:FS01:Uploading 1.51MiB to 171.67.108.60
16:07:51:WU01:FS01:Starting
16:07:51:WU00:FS01:Connecting to 171.67.108.60:8080
16:07:51:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
16:07:51:WU01:FS01:Started FahCore on PID 4672
16:07:51:WU01:FS01:Core PID:5256
16:07:51:WU01:FS01:FahCore 0xa4 started
16:07:52:WU01:FS01:0xa4:
16:07:52:WU01:FS01:0xa4:*------------------------------*
16:07:52:WU01:FS01:0xa4:[email protected] Gromacs GB Core
16:07:52:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
16:07:52:WU01:FS01:0xa4:Preparing to commence simulation
16:07:52:WU01:FS01:0xa4:- Looking at optimizations...
16:07:52:WU01:FS01:0xa4:- Created dyn
16:07:52:WU01:FS01:0xa4:- Files status OK
16:07:52:WU01:FS01:0xa4:- Expanded 525228 -> 1190768 (decompressed 226.7 percent)
16:07:52:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525228 data_size=1190768, decompressed_data_size=1190768 diff=0
16:07:52:WU01:FS01:0xa4:- Digital signature verified
16:07:52:WU01:FS01:0xa4:Project: 8028 (Run 495, Clone 0, Gen 79)
16:07:52:WU01:FS01:0xa4:Assembly optimizations on if available.
16:07:52:WU01:FS01:0xa4:Entering M.D.
16:07:58:WU01:FS01:0xa4:Mapping NT from 8 to 8
16:07:58:WU01:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
16:08:02:WU00:FS01:Upload complete
16:08:02:WU00:FS01:Server responded WORK_ACK (400)
16:08:02:WU00:FS01:Final credit estimate, 2068.00 points
16:08:02:WU00:FS01:Cleaning up
16:08:59:WU01:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
16:10:01:WU01:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
16:11:02:WU01:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
16:12:05:WU01:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
16:13:05:WU01:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
16:14:07:WU01:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
16:15:09:WU01:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
16:16:10:WU01:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
16:17:13:WU01:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
16:18:15:WU01:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
16:19:17:WU01:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
16:20:20:WU01:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
16:21:20:WU01:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
16:22:24:WU01:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
16:23:25:WU01:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
16:24:28:WU01:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
16:25:29:WU01:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
16:26:32:WU01:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
16:27:33:WU01:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
16:28:36:WU01:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
16:29:36:WU01:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
16:30:39:WU01:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
16:31:40:WU01:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
16:32:43:WU01:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
16:33:44:WU01:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
16:34:47:WU01:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
16:35:48:WU01:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
16:36:49:WU01:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
16:37:52:WU01:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
16:38:53:WU01:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
16:39:56:WU01:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
16:40:57:WU01:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
16:41:59:WU01:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
16:43:00:WU01:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
16:44:03:WU01:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
16:45:11:WU01:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
16:46:14:WU01:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
16:47:15:WU01:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
16:48:17:WU01:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
16:49:18:WU01:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
16:50:21:WU01:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
16:51:21:WU01:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
16:52:24:WU01:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
16:53:25:WU01:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
16:54:27:WU01:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
16:55:31:WU01:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
16:56:32:WU01:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
16:57:34:WU01:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
16:58:35:WU01:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
16:59:36:WU01:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
17:00:38:WU01:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
17:01:39:WU01:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
17:02:40:WU01:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
17:03:42:WU01:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
17:04:43:WU01:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
17:05:46:WU01:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
17:06:46:WU01:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
17:07:49:WU01:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
17:08:50:WU01:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
17:09:52:WU01:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
17:10:53:WU01:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
17:11:56:WU01:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
17:12:57:WU01:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
17:14:00:WU01:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
17:15:00:WU01:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
17:16:03:WU01:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
17:17:04:WU01:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
17:18:06:WU01:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
17:19:07:WU01:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
17:20:09:WU01:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
17:21:10:WU01:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
17:22:12:WU01:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
17:23:13:WU01:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
17:24:15:WU01:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
17:25:16:WU01:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
17:26:18:WU01:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
17:27:18:WU01:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
17:28:19:WU01:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
17:29:21:WU01:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
17:30:21:WU01:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
17:31:22:WU01:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
17:32:24:WU01:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
17:33:25:WU01:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
17:34:25:WU01:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
17:35:27:WU01:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
17:36:30:WU01:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
17:37:30:WU01:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
17:38:31:WU01:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
17:39:34:WU01:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
17:40:34:WU01:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
17:41:37:WU01:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
17:42:37:WU01:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
17:43:40:WU01:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
17:44:46:WU01:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
17:45:46:WU01:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
17:46:47:WU01:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
17:47:49:WU01:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
17:48:49:WU01:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
17:49:52:WU01:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
17:49:52:WU00:FS01:Connecting to assign3.stanford.edu:8080
17:49:52:WU00:FS01:News: Welcome to [email protected]
17:49:52:WU00:FS01:Assigned to work server 171.67.108.60
17:49:52:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
17:49:52:WU00:FS01:Connecting to 171.67.108.60:8080
17:49:54:WU00:FS01:Downloading 940.50KiB
17:49:54:WU00:FS01:Download complete
17:49:54:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8049 run:508 clone:8 gen:37 core:0xa4 unit:0x0000003b6652edcc5013349e0b405de2
17:50:52:WU01:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
17:50:52:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
17:51:02:WU01:FS01:0xa4:
17:51:02:WU01:FS01:0xa4:Finished Work Unit:
17:51:02:WU01:FS01:0xa4:- Reading up to 770964 from "01/wudata_01.trr": Read 770964
17:51:02:WU01:FS01:0xa4:trr file hash check passed.
17:51:02:WU01:FS01:0xa4:- Reading up to 836644 from "01/wudata_01.xtc": Read 836644
17:51:02:WU01:FS01:0xa4:xtc file hash check passed.
17:51:02:WU01:FS01:0xa4:edr file hash check passed.
17:51:02:WU01:FS01:0xa4:logfile size: 26338
17:51:02:WU01:FS01:0xa4:Leaving Run
17:51:05:WU01:FS01:0xa4:- Writing 1642770 bytes of core data to disk...
17:51:05:WU01:FS01:0xa4:Done: 1642258 -> 1580619 (compressed to 96.2 percent)
17:51:05:WU01:FS01:0xa4:  ... Done.
17:51:06:WU01:FS01:0xa4:- Shutting down core
17:51:06:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
17:51:06:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:51:06:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8028 run:495 clone:0 gen:79 core:0xa4 unit:0x000000846652edcc50e7903e6b028740
17:51:06:WU01:FS01:Uploading 1.51MiB to 171.67.108.60
17:51:06:WU00:FS01:Starting
17:51:06:WU01:FS01:Connecting to 171.67.108.60:8080
17:51:06:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
17:51:06:WU00:FS01:Started FahCore on PID 2864
17:51:06:WU00:FS01:Core PID:5404
17:51:06:WU00:FS01:FahCore 0xa4 started
17:51:07:WU00:FS01:0xa4:
17:51:07:WU00:FS01:0xa4:*------------------------------*
17:51:07:WU00:FS01:0xa4:[email protected] Gromacs GB Core
17:51:07:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
17:51:07:WU00:FS01:0xa4:Preparing to commence simulation
17:51:07:WU00:FS01:0xa4:- Looking at optimizations...
17:51:07:WU00:FS01:0xa4:- Created dyn
17:51:07:WU00:FS01:0xa4:- Files status OK
17:51:07:WU00:FS01:0xa4:- Expanded 962561 -> 2211260 (decompressed 229.7 percent)
17:51:07:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=962561 data_size=2211260, decompressed_data_size=2211260 diff=0
17:51:07:WU00:FS01:0xa4:- Digital signature verified
17:51:07:WU00:FS01:0xa4:Project: 8049 (Run 508, Clone 8, Gen 37)
17:51:07:WU00:FS01:0xa4:Assembly optimizations on if available.
17:51:07:WU00:FS01:0xa4:Entering M.D.
17:51:13:WU00:FS01:0xa4:Mapping NT from 8 to 8
17:51:13:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
17:51:17:WU01:FS01:Upload complete
17:51:17:WU01:FS01:Server responded WORK_ACK (400)
17:51:17:WU01:FS01:Final credit estimate, 2069.00 points
17:51:17:WU01:FS01:Cleaning up
17:52:12:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
17:53:11:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
17:54:12:WU00:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
17:55:11:WU00:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
17:56:13:WU00:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
17:57:13:WU00:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
17:58:14:WU00:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
17:59:15:WU00:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
18:00:16:WU00:FS01:0xa4:Completed 22500 out of 250000 steps  (9%)
18:01:17:WU00:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
18:02:16:WU00:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
18:03:17:WU00:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
18:04:16:WU00:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
18:05:17:WU00:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
18:06:16:WU00:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
18:07:17:WU00:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
18:08:28:WU00:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
18:09:34:WU00:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
18:10:38:WU00:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
18:11:41:WU00:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
18:12:44:WU00:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
18:13:46:WU00:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
18:14:52:WU00:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
18:15:55:WU00:FS01:0xa4:Completed 60000 out of 250000 steps  (24%)
18:16:53:WU00:FS01:0xa4:Completed 62500 out of 250000 steps  (25%)
18:17:53:WU00:FS01:0xa4:Completed 65000 out of 250000 steps  (26%)
18:18:52:WU00:FS01:0xa4:Completed 67500 out of 250000 steps  (27%)
18:19:52:WU00:FS01:0xa4:Completed 70000 out of 250000 steps  (28%)
18:20:51:WU00:FS01:0xa4:Completed 72500 out of 250000 steps  (29%)
18:21:52:WU00:FS01:0xa4:Completed 75000 out of 250000 steps  (30%)
18:22:56:WU00:FS01:0xa4:Completed 77500 out of 250000 steps  (31%)
18:24:12:WU00:FS01:0xa4:Completed 80000 out of 250000 steps  (32%)
18:25:18:WU00:FS01:0xa4:Completed 82500 out of 250000 steps  (33%)
18:26:28:WU00:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
18:27:35:WU00:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
18:28:37:WU00:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
18:29:43:WU00:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
18:30:53:WU00:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
18:31:56:WU00:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
18:32:56:WU00:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
18:33:56:WU00:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
18:34:57:WU00:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
18:35:58:WU00:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
18:37:05:WU00:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
18:38:08:WU00:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
18:39:12:WU00:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
18:40:15:WU00:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
18:41:18:WU00:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
18:42:21:WU00:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
18:43:23:WU00:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
18:44:32:WU00:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
18:45:35:WU00:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
18:46:37:WU00:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
18:47:42:WU00:FS01:0xa4:Completed 135000 out of 250000 steps  (54%)
18:48:45:WU00:FS01:0xa4:Completed 137500 out of 250000 steps  (55%)
18:49:50:WU00:FS01:0xa4:Completed 140000 out of 250000 steps  (56%)
18:50:50:WU00:FS01:0xa4:Completed 142500 out of 250000 steps  (57%)
18:51:53:WU00:FS01:0xa4:Completed 145000 out of 250000 steps  (58%)
18:52:56:WU00:FS01:0xa4:Completed 147500 out of 250000 steps  (59%)
18:54:01:WU00:FS01:0xa4:Completed 150000 out of 250000 steps  (60%)
18:55:02:WU00:FS01:0xa4:Completed 152500 out of 250000 steps  (61%)
18:56:06:WU00:FS01:0xa4:Completed 155000 out of 250000 steps  (62%)
18:57:18:WU00:FS01:0xa4:Completed 157500 out of 250000 steps  (63%)
18:58:17:WU00:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
18:59:19:WU00:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
19:00:21:WU00:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
19:01:20:WU00:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
19:02:25:WU00:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
19:03:27:WU00:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
19:04:30:WU00:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
19:05:28:WU00:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
19:06:29:WU00:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
19:07:28:WU00:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
19:08:28:WU00:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
19:09:29:WU00:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
19:10:27:WU00:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
19:11:28:WU00:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
19:12:26:WU00:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
19:13:27:WU00:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
19:14:25:WU00:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
19:15:25:WU00:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
19:16:24:WU00:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
19:17:24:WU00:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
19:18:23:WU00:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
19:19:23:WU00:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
19:20:21:WU00:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
19:21:20:WU00:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
19:22:21:WU00:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
19:23:19:WU00:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
19:24:18:WU00:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
19:25:18:WU00:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
19:26:15:WU00:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
19:27:15:WU00:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
19:28:13:WU00:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
19:29:14:WU00:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
19:30:12:WU00:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
19:31:12:WU00:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
19:32:10:WU00:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
19:33:10:WU00:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
19:34:09:WU00:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
19:34:10:WU01:FS01:Connecting to assign3.stanford.edu:8080
19:34:10:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
19:34:10:WU01:FS01:News: Welcome to [email protected]
19:34:10:WU01:FS01:Assigned to work server 171.67.108.60
19:34:10:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
19:34:10:WU01:FS01:Connecting to 171.67.108.60:8080
19:34:12:WU01:FS01:Downloading 512.13KiB
19:34:12:WU01:FS01:Download complete
19:34:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8028 run:2023 clone:0 gen:33 core:0xa4 unit:0x000000356652edcc50e795e26844f5ca
19:34:20:WU00:FS01:0xa4:
19:34:20:WU00:FS01:0xa4:Finished Work Unit:
19:34:20:WU00:FS01:0xa4:- Reading up to 1406904 from "00/wudata_01.trr": Read 1406904
19:34:20:WU00:FS01:0xa4:trr file hash check passed.
19:34:20:WU00:FS01:0xa4:- Reading up to 851652 from "00/wudata_01.xtc": Read 851652
19:34:20:WU00:FS01:0xa4:xtc file hash check passed.
19:34:20:WU00:FS01:0xa4:edr file hash check passed.
19:34:20:WU00:FS01:0xa4:logfile size: 22429
19:34:20:WU00:FS01:0xa4:Leaving Run
19:34:22:WU00:FS01:0xa4:- Writing 2286389 bytes of core data to disk...
19:34:23:WU00:FS01:0xa4:Done: 2285877 -> 2190810 (compressed to 95.8 percent)
19:34:23:WU00:FS01:0xa4:  ... Done.
19:34:23:WU00:FS01:0xa4:- Shutting down core
19:34:23:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
19:34:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:34:24:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8049 run:508 clone:8 gen:37 core:0xa4 unit:0x0000003b6652edcc5013349e0b405de2
19:34:24:WU00:FS01:Uploading 2.09MiB to 171.67.108.60
19:34:24:WU01:FS01:Starting
19:34:24:WU00:FS01:Connecting to 171.67.108.60:8080
19:34:24:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
19:34:24:WU01:FS01:Started FahCore on PID 5852
19:34:24:WU01:FS01:Core PID:1916
19:34:24:WU01:FS01:FahCore 0xa4 started
19:34:25:WU01:FS01:0xa4:
19:34:25:WU01:FS01:0xa4:*------------------------------*
19:34:25:WU01:FS01:0xa4:[email protected] Gromacs GB Core
19:34:25:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
19:34:25:WU01:FS01:0xa4:Preparing to commence simulation
19:34:25:WU01:FS01:0xa4:- Looking at optimizations...
19:34:25:WU01:FS01:0xa4:- Created dyn
19:34:25:WU01:FS01:0xa4:- Files status OK
19:34:25:WU01:FS01:0xa4:- Expanded 523904 -> 1188176 (decompressed 226.7 percent)
19:34:25:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=523904 data_size=1188176, decompressed_data_size=1188176 diff=0
19:34:25:WU01:FS01:0xa4:- Digital signature verified
19:34:25:WU01:FS01:0xa4:Project: 8028 (Run 2023, Clone 0, Gen 33)
19:34:25:WU01:FS01:0xa4:Assembly optimizations on if available.
19:34:25:WU01:FS01:0xa4:Entering M.D.
19:34:30:WU00:FS01:Upload 41.87%
19:34:30:WU01:FS01:0xa4:Mapping NT from 8 to 8
19:34:31:WU01:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
19:34:36:WU00:FS01:Upload 83.74%
19:34:39:WU00:FS01:Upload complete
19:34:39:WU00:FS01:Server responded WORK_ACK (400)
19:34:39:WU00:FS01:Final credit estimate, 1855.00 points
19:34:39:WU00:FS01:Cleaning up
19:35:35:WU01:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
19:36:36:WU01:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
19:37:37:WU01:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
19:38:37:WU01:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
19:39:39:WU01:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
19:40:39:WU01:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
19:41:41:WU01:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
19:42:41:WU01:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
19:43:43:WU01:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
19:44:45:WU01:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
19:45:47:WU01:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
19:46:47:WU01:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
19:47:49:WU01:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
19:48:49:WU01:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
19:49:51:WU01:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
19:50:51:WU01:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
19:52:02:WU01:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
19:53:09:WU01:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
19:54:22:WU01:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
19:55:38:WU01:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
19:56:48:WU01:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
19:57:51:WU01:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
19:58:56:WU01:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
20:00:06:WU01:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
20:01:21:WU01:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
20:02:29:WU01:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
20:03:35:WU01:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
20:05:24:WU01:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
20:06:30:WU01:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
20:07:40:WU01:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
20:08:52:WU01:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
20:10:03:WU01:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
20:11:11:WU01:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
20:12:18:WU01:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
20:13:26:WU01:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
20:14:34:WU01:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
20:15:42:WU01:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
20:16:51:WU01:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
20:18:01:WU01:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
20:19:13:WU01:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
20:20:23:WU01:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
20:21:37:WU01:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
20:22:45:WU01:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
20:23:58:WU01:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
20:25:16:WU01:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
20:26:27:WU01:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
20:27:41:WU01:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
20:28:51:WU01:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
20:29:56:WU01:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
20:31:06:WU01:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
20:32:14:WU01:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
20:33:20:WU01:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
20:34:30:WU01:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
20:35:40:WU01:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
20:36:48:WU01:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
20:37:54:WU01:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
20:39:06:WU01:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
20:40:17:WU01:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
20:41:26:WU01:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
20:42:39:WU01:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
20:48:45:WU01:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
20:50:18:WU01:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
20:51:33:WU01:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
20:52:42:WU01:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
20:53:48:WU01:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
20:54:56:WU01:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
20:56:09:WU01:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
20:57:15:WU01:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
20:58:23:WU01:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
20:59:29:WU01:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
21:00:35:WU01:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
21:01:43:WU01:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
21:02:49:WU01:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
21:03:56:WU01:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
21:05:04:WU01:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
21:06:10:WU01:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
21:07:16:WU01:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
21:08:25:WU01:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
21:09:31:WU01:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
21:10:37:WU01:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
21:11:45:WU01:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
21:12:51:WU01:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
21:13:57:WU01:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
21:15:04:WU01:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
21:16:17:WU01:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
21:17:23:WU01:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
21:18:29:WU01:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
21:19:38:WU01:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
21:20:50:WU01:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
21:21:59:WU01:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
21:23:08:WU01:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
21:24:16:WU01:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
21:25:26:WU01:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
21:26:33:WU01:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
21:27:37:WU01:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
21:28:41:WU01:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
21:29:30:FS01:Paused
21:29:31:FS01:Shutting core down
21:29:39:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:42:59:FS01:Unpaused
21:42:59:WU01:FS01:Starting
21:42:59:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
21:42:59:WU01:FS01:Started FahCore on PID 2148
21:42:59:WU01:FS01:Core PID:852
21:42:59:WU01:FS01:FahCore 0xa4 started
21:43:00:WU01:FS01:0xa4:
21:43:00:WU01:FS01:0xa4:*------------------------------*
21:43:00:WU01:FS01:0xa4:[email protected] Gromacs GB Core
21:43:00:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:43:00:WU01:FS01:0xa4:Preparing to commence simulation
21:43:00:WU01:FS01:0xa4:- Looking at optimizations...
21:43:00:WU01:FS01:0xa4:- Files status OK
21:43:00:WU01:FS01:0xa4:- Expanded 523904 -> 1188176 (decompressed 226.7 percent)
21:43:00:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=523904 data_size=1188176, decompressed_data_size=1188176 diff=0
21:43:00:WU01:FS01:0xa4:- Digital signature verified
21:43:00:WU01:FS01:0xa4:Project: 8028 (Run 2023, Clone 0, Gen 33)
21:43:00:WU01:FS01:0xa4:Assembly optimizations on if available.
21:43:00:WU01:FS01:0xa4:Entering M.D.
21:43:06:WU01:FS01:0xa4:Using Gromacs checkpoints
21:43:06:WU01:FS01:0xa4:Mapping NT from 8 to 8
21:43:06:WU01:FS01:0xa4:Resuming from checkpoint
21:43:06:WU01:FS01:0xa4:Verified 01/wudata_01.log
21:43:06:WU01:FS01:0xa4:Verified 01/wudata_01.trr
21:43:06:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
21:43:06:WU01:FS01:0xa4:Verified 01/wudata_01.edr
21:43:06:WU01:FS01:0xa4:Completed 439350 out of 500000 steps  (87%)
21:43:14:WU01:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
21:44:16:WU01:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
21:45:18:WU01:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
21:46:18:WU01:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
21:47:21:WU01:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
21:48:22:WU01:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
21:49:25:WU01:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
21:50:25:WU01:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
21:51:27:WU01:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
21:52:28:WU01:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
21:53:30:WU01:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
21:54:31:WU01:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
21:54:31:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:54:31:WU00:FS01:News: Welcome to [email protected]
21:54:31:WU00:FS01:Assigned to work server 171.67.108.60
21:54:31:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
21:54:31:WU00:FS01:Connecting to 171.67.108.60:8080
21:54:33:WU00:FS01:Downloading 944.82KiB
21:54:33:WU00:FS01:Download complete
21:54:33:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8049 run:476 clone:11 gen:185 core:0xa4 unit:0x000001206652edcc501333e63c57ee95
21:55:33:WU01:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
21:55:34:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
21:55:44:WU01:FS01:0xa4:
21:55:44:WU01:FS01:0xa4:Finished Work Unit:
21:55:44:WU01:FS01:0xa4:- Reading up to 769020 from "01/wudata_01.trr": Read 769020
21:55:44:WU01:FS01:0xa4:trr file hash check passed.
21:55:44:WU01:FS01:0xa4:- Reading up to 834292 from "01/wudata_01.xtc": Read 834292
21:55:44:WU01:FS01:0xa4:xtc file hash check passed.
21:55:44:WU01:FS01:0xa4:edr file hash check passed.
21:55:44:WU01:FS01:0xa4:logfile size: 27242
21:55:44:WU01:FS01:0xa4:Leaving Run
21:55:45:WU01:FS01:0xa4:- Writing 1639378 bytes of core data to disk...
21:55:46:WU01:FS01:0xa4:Done: 1638866 -> 1576477 (compressed to 96.1 percent)
21:55:46:WU01:FS01:0xa4:  ... Done.
21:55:46:WU01:FS01:0xa4:- Shutting down core
21:55:46:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
21:55:46:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:55:46:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8028 run:2023 clone:0 gen:33 core:0xa4 unit:0x000000356652edcc50e795e26844f5ca
21:55:46:WU01:FS01:Uploading 1.50MiB to 171.67.108.60
21:55:46:WU00:FS01:Starting
21:55:46:WU01:FS01:Connecting to 171.67.108.60:8080
21:55:46:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
21:55:46:WU00:FS01:Started FahCore on PID 3364
21:55:46:WU00:FS01:Core PID:1352
21:55:46:WU00:FS01:FahCore 0xa4 started
21:55:47:WU00:FS01:0xa4:
21:55:47:WU00:FS01:0xa4:*------------------------------*
21:55:47:WU00:FS01:0xa4:[email protected] Gromacs GB Core
21:55:47:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:55:47:WU00:FS01:0xa4:Preparing to commence simulation
21:55:47:WU00:FS01:0xa4:- Looking at optimizations...
21:55:47:WU00:FS01:0xa4:- Created dyn
21:55:47:WU00:FS01:0xa4:- Files status OK
21:55:47:WU00:FS01:0xa4:- Expanded 966982 -> 2211548 (decompressed 228.7 percent)
21:55:47:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=966982 data_size=2211548, decompressed_data_size=2211548 diff=0
21:55:47:WU00:FS01:0xa4:- Digital signature verified
21:55:47:WU00:FS01:0xa4:Project: 8049 (Run 476, Clone 11, Gen 185)
21:55:47:WU00:FS01:0xa4:Assembly optimizations on if available.
21:55:47:WU00:FS01:0xa4:Entering M.D.
21:55:52:WU00:FS01:0xa4:Mapping NT from 8 to 8
21:55:53:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
21:55:55:WU01:FS01:Upload complete
21:55:55:WU01:FS01:Server responded WORK_ACK (400)
21:55:55:WU01:FS01:Final credit estimate, 1779.00 points
21:55:55:WU01:FS01:Cleaning up
21:56:53:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
21:57:53:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
21:58:55:WU00:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
21:59:54:WU00:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
22:00:53:WU00:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
22:01:55:WU00:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
22:02:54:WU00:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
22:03:55:WU00:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
22:05:03:WU00:FS01:0xa4:Completed 22500 out of 250000 steps  (9%)
22:06:02:WU00:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
22:07:04:WU00:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
22:08:03:WU00:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
22:09:04:WU00:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
22:10:03:WU00:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
22:11:03:WU00:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
22:12:03:WU00:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
22:13:02:WU00:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
22:14:02:WU00:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
22:15:03:WU00:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
22:16:02:WU00:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
22:17:03:WU00:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
22:18:05:WU00:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
22:19:04:WU00:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
22:20:05:WU00:FS01:0xa4:Completed 60000 out of 250000 steps  (24%)
22:21:05:WU00:FS01:0xa4:Completed 62500 out of 250000 steps  (25%)
22:22:04:WU00:FS01:0xa4:Completed 65000 out of 250000 steps  (26%)
22:23:06:WU00:FS01:0xa4:Completed 67500 out of 250000 steps  (27%)
22:24:06:WU00:FS01:0xa4:Completed 70000 out of 250000 steps  (28%)
22:25:08:WU00:FS01:0xa4:Completed 72500 out of 250000 steps  (29%)
22:26:08:WU00:FS01:0xa4:Completed 75000 out of 250000 steps  (30%)
22:27:08:WU00:FS01:0xa4:Completed 77500 out of 250000 steps  (31%)
22:28:09:WU00:FS01:0xa4:Completed 80000 out of 250000 steps  (32%)
22:29:08:WU00:FS01:0xa4:Completed 82500 out of 250000 steps  (33%)
22:30:09:WU00:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
22:31:10:WU00:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
22:32:10:WU00:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
22:33:12:WU00:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
22:34:12:WU00:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
22:35:12:WU00:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
22:36:14:WU00:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
22:37:14:WU00:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
22:38:17:WU00:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
22:39:17:WU00:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
22:40:20:WU00:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
22:41:23:WU00:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
22:42:25:WU00:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
22:43:28:WU00:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
22:44:30:WU00:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
22:45:34:WU00:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
22:46:34:WU00:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
22:47:38:WU00:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
22:48:38:WU00:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
22:49:41:WU00:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
22:50:42:WU00:FS01:0xa4:Completed 135000 out of 250000 steps  (54%)
22:51:44:WU00:FS01:0xa4:Completed 137500 out of 250000 steps  (55%)
22:52:45:WU00:FS01:0xa4:Completed 140000 out of 250000 steps  (56%)
22:53:46:WU00:FS01:0xa4:Completed 142500 out of 250000 steps  (57%)
22:54:48:WU00:FS01:0xa4:Completed 145000 out of 250000 steps  (58%)
22:55:49:WU00:FS01:0xa4:Completed 147500 out of 250000 steps  (59%)
22:56:50:WU00:FS01:0xa4:Completed 150000 out of 250000 steps  (60%)
22:57:53:WU00:FS01:0xa4:Completed 152500 out of 250000 steps  (61%)
22:58:53:WU00:FS01:0xa4:Completed 155000 out of 250000 steps  (62%)
22:59:57:WU00:FS01:0xa4:Completed 157500 out of 250000 steps  (63%)
23:00:58:WU00:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
23:02:01:WU00:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
23:03:01:WU00:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
23:04:02:WU00:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
23:05:12:WU00:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
23:06:13:WU00:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
23:07:15:WU00:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
23:08:16:WU00:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
23:09:19:WU00:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
23:10:19:WU00:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
23:11:22:WU00:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
23:12:22:WU00:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
23:13:22:WU00:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
23:14:25:WU00:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
23:15:25:WU00:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
23:16:27:WU00:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
23:17:28:WU00:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
23:18:28:WU00:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
23:19:31:WU00:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
23:20:31:WU00:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
23:21:32:WU00:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
23:22:33:WU00:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
23:23:33:WU00:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
23:24:33:WU00:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
23:25:34:WU00:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
23:26:36:WU00:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
23:27:37:WU00:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
23:28:39:WU00:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
23:29:39:WU00:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
23:30:40:WU00:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
23:31:42:WU00:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
23:32:42:WU00:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
23:33:44:WU00:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
23:34:44:WU00:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
23:35:47:WU00:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
23:36:49:WU00:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
23:37:49:WU00:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
23:37:49:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:37:50:WU01:FS01:Connecting to assign3.stanford.edu:8080
23:37:51:WU01:FS01:News: Welcome to [email protected]
23:37:51:WU01:FS01:Assigned to work server 171.67.108.60
23:37:51:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
23:37:51:WU01:FS01:Connecting to 171.67.108.60:8080
23:37:53:WU01:FS01:Downloading 945.20KiB
23:37:53:WU01:FS01:Download complete
23:37:53:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8049 run:453 clone:5 gen:102 core:0xa4 unit:0x0000009f6652edcc5013335d90312056
23:37:59:WU00:FS01:0xa4:
23:37:59:WU00:FS01:0xa4:Finished Work Unit:
23:37:59:WU00:FS01:0xa4:- Reading up to 1407120 from "00/wudata_01.trr": Read 1407120
23:37:59:WU00:FS01:0xa4:trr file hash check passed.
23:37:59:WU00:FS01:0xa4:- Reading up to 852116 from "00/wudata_01.xtc": Read 852116
23:37:59:WU00:FS01:0xa4:xtc file hash check passed.
23:37:59:WU00:FS01:0xa4:edr file hash check passed.
23:37:59:WU00:FS01:0xa4:logfile size: 22437
23:37:59:WU00:FS01:0xa4:Leaving Run
23:38:02:WU00:FS01:0xa4:- Writing 2287077 bytes of core data to disk...
23:38:02:WU00:FS01:0xa4:Done: 2286565 -> 2191363 (compressed to 95.8 percent)
23:38:02:WU00:FS01:0xa4:  ... Done.
23:38:02:WU00:FS01:0xa4:- Shutting down core
23:38:02:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
23:38:03:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:38:03:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8049 run:476 clone:11 gen:185 core:0xa4 unit:0x000001206652edcc501333e63c57ee95
23:38:03:WU00:FS01:Uploading 2.09MiB to 171.67.108.60
23:38:03:WU01:FS01:Starting
23:38:03:WU00:FS01:Connecting to 171.67.108.60:8080
23:38:03:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
23:38:03:WU01:FS01:Started FahCore on PID 4044
23:38:03:WU01:FS01:Core PID:3056
23:38:03:WU01:FS01:FahCore 0xa4 started
23:38:04:WU01:FS01:0xa4:
23:38:04:WU01:FS01:0xa4:*------------------------------*
23:38:04:WU01:FS01:0xa4:[email protected] Gromacs GB Core
23:38:04:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:38:04:WU01:FS01:0xa4:Preparing to commence simulation
23:38:04:WU01:FS01:0xa4:- Looking at optimizations...
23:38:04:WU01:FS01:0xa4:- Created dyn
23:38:04:WU01:FS01:0xa4:- Files status OK
23:38:04:WU01:FS01:0xa4:- Expanded 967371 -> 2212556 (decompressed 228.7 percent)
23:38:04:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=967371 data_size=2212556, decompressed_data_size=2212556 diff=0
23:38:04:WU01:FS01:0xa4:- Digital signature verified
23:38:04:WU01:FS01:0xa4:Project: 8049 (Run 453, Clone 5, Gen 102)
23:38:04:WU01:FS01:0xa4:Assembly optimizations on if available.
23:38:04:WU01:FS01:0xa4:Entering M.D.
23:38:09:WU00:FS01:Upload 38.87%
23:38:09:WU01:FS01:0xa4:Mapping NT from 8 to 8
23:38:10:WU01:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
23:38:15:WU00:FS01:Upload 71.76%
23:38:20:WU00:FS01:Upload complete
23:38:20:WU00:FS01:Server responded WORK_ACK (400)
23:38:20:WU00:FS01:Final credit estimate, 1864.00 points
23:38:20:WU00:FS01:Cleaning up
23:39:10:WU01:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
23:40:11:WU01:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
23:41:11:WU01:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
23:42:11:WU01:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
23:43:13:WU01:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
23:44:15:WU01:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
23:45:17:WU01:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
23:46:17:WU01:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
23:47:18:WU01:FS01:0xa4:Completed 22500 out of 250000 steps  (9%)
23:48:18:WU01:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
23:49:18:WU01:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
23:50:19:WU01:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
23:51:19:WU01:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
23:52:22:WU01:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
23:53:21:WU01:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
23:54:23:WU01:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
23:55:22:WU01:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
23:56:23:WU01:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
23:57:22:WU01:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
23:58:21:WU01:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
23:59:22:WU01:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
00:00:22:WU01:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
00:01:24:WU01:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
00:02:24:WU01:FS01:0xa4:Completed 60000 out of 250000 steps  (24%)
00:03:25:WU01:FS01:0xa4:Completed 62500 out of 250000 steps  (25%)
00:04:26:WU01:FS01:0xa4:Completed 65000 out of 250000 steps  (26%)
00:05:27:WU01:FS01:0xa4:Completed 67500 out of 250000 steps  (27%)
00:06:27:WU01:FS01:0xa4:Completed 70000 out of 250000 steps  (28%)
00:07:29:WU01:FS01:0xa4:Completed 72500 out of 250000 steps  (29%)
00:08:28:WU01:FS01:0xa4:Completed 75000 out of 250000 steps  (30%)
00:09:32:WU01:FS01:0xa4:Completed 77500 out of 250000 steps  (31%)
00:10:31:WU01:FS01:0xa4:Completed 80000 out of 250000 steps  (32%)
00:11:30:WU01:FS01:0xa4:Completed 82500 out of 250000 steps  (33%)
00:12:37:WU01:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
00:13:37:WU01:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
00:14:39:WU01:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
00:15:37:WU01:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
00:16:37:WU01:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
00:17:38:WU01:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
00:18:38:WU01:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
00:19:39:WU01:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
00:20:41:WU01:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
00:21:40:WU01:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
00:22:42:WU01:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
00:23:41:WU01:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
00:24:42:WU01:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
00:25:42:WU01:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
00:26:40:WU01:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
00:27:45:WU01:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
00:28:43:WU01:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
00:29:58:WU01:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
00:31:05:WU01:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
00:32:18:FS01:Paused
00:32:19:FS01:Shutting core down
00:32:27:WU01:FS01:0xa4:Client no longer detected. Shutting down core
00:32:27:WU01:FS01:0xa4:[email protected] Core Shutdown: CLIENT_DIED
00:33:20:WARNING:FS01:Killing WU01
00:33:20:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
******************************** Date: 16/02/13 ********************************
04:01:45:FS01:Unpaused
04:01:46:WU01:FS01:Starting
04:01:46:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
04:01:46:WU01:FS01:Started FahCore on PID 5548
04:01:46:WU01:FS01:Core PID:5240
04:01:46:WU01:FS01:FahCore 0xa4 started
04:01:46:WU01:FS01:0xa4:
04:01:46:WU01:FS01:0xa4:*------------------------------*
04:01:46:WU01:FS01:0xa4:[email protected] Gromacs GB Core
04:01:46:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:01:46:WU01:FS01:0xa4:Preparing to commence simulation
04:01:46:WU01:FS01:0xa4:- Looking at optimizations...
04:01:46:WU01:FS01:0xa4:- Files status OK
04:01:46:WU01:FS01:0xa4:- Expanded 967371 -> 2212556 (decompressed 228.7 percent)
04:01:46:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=967371 data_size=2212556, decompressed_data_size=2212556 diff=0
04:01:46:WU01:FS01:0xa4:- Digital signature verified
04:01:46:WU01:FS01:0xa4:Project: 8049 (Run 453, Clone 5, Gen 102)
04:01:46:WU01:FS01:0xa4:Assembly optimizations on if available.
04:01:46:WU01:FS01:0xa4:Entering M.D.
04:01:52:WU01:FS01:0xa4:Using Gromacs checkpoints
04:01:52:WU01:FS01:0xa4:Mapping NT from 8 to 8
04:01:52:WU01:FS01:0xa4:Resuming from checkpoint
04:01:52:WU01:FS01:0xa4:Verified 01/wudata_01.log
04:01:52:WU01:FS01:0xa4:Verified 01/wudata_01.trr
04:01:52:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
04:01:52:WU01:FS01:0xa4:Verified 01/wudata_01.edr
04:01:52:WU01:FS01:0xa4:Completed 111160 out of 250000 steps  (44%)
04:02:24:WU01:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
04:03:24:WU01:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
04:04:32:WU01:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
04:05:32:WU01:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
04:06:31:WU01:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
04:07:36:WU01:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
04:08:37:WU01:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
04:09:48:WU01:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
04:10:53:WU01:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
04:12:10:WU01:FS01:0xa4:Completed 135000 out of 250000 steps  (54%)
04:13:13:WU01:FS01:0xa4:Completed 137500 out of 250000 steps  (55%)
04:14:14:WU01:FS01:0xa4:Completed 140000 out of 250000 steps  (56%)
04:15:18:WU01:FS01:0xa4:Completed 142500 out of 250000 steps  (57%)
04:16:21:WU01:FS01:0xa4:Completed 145000 out of 250000 steps  (58%)
04:17:25:WU01:FS01:0xa4:Completed 147500 out of 250000 steps  (59%)
04:18:30:WU01:FS01:0xa4:Completed 150000 out of 250000 steps  (60%)
04:19:33:WU01:FS01:0xa4:Completed 152500 out of 250000 steps  (61%)
04:20:40:WU01:FS01:0xa4:Completed 155000 out of 250000 steps  (62%)
04:21:44:WU01:FS01:0xa4:Completed 157500 out of 250000 steps  (63%)
04:22:45:WU01:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
04:23:43:WU01:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
04:24:44:WU01:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
04:25:42:WU01:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
04:26:42:WU01:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
04:27:41:WU01:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
04:28:42:WU01:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
04:29:41:WU01:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
04:30:42:WU01:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
04:31:41:WU01:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
04:32:40:WU01:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
04:33:41:WU01:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
04:34:40:WU01:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
04:35:40:WU01:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
04:36:39:WU01:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
04:37:40:WU01:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
04:38:39:WU01:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
04:39:39:WU01:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
04:40:38:WU01:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
04:41:39:WU01:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
04:42:38:WU01:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
04:43:40:WU01:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
04:44:40:WU01:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
04:45:48:WU01:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
04:46:56:WU01:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
04:48:00:WU01:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
04:49:08:WU01:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
04:50:13:WU01:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
04:51:17:WU01:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
04:52:22:WU01:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
04:53:25:WU01:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
04:54:25:WU01:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
04:55:30:WU01:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
04:56:32:WU01:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
04:57:37:WU01:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
04:58:52:WU01:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
05:00:03:WU01:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
05:00:04:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:00:04:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:00:04:WU00:FS01:News: Welcome to [email protected]
05:00:04:WU00:FS01:Assigned to work server 171.67.108.60
05:00:04:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
05:00:04:WU00:FS01:Connecting to 171.67.108.60:8080
05:00:06:WU00:FS01:Downloading 513.67KiB
05:00:06:WU00:FS01:Download complete
05:00:06:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8028 run:286 clone:1 gen:56 core:0xa4 unit:0x0000005c6652edcc50e78f78e51e0751
05:00:14:WU01:FS01:0xa4:
05:00:14:WU01:FS01:0xa4:Finished Work Unit:
05:00:14:WU01:FS01:0xa4:- Reading up to 1407876 from "01/wudata_01.trr": Read 1407876
05:00:14:WU01:FS01:0xa4:trr file hash check passed.
05:00:14:WU01:FS01:0xa4:- Reading up to 852472 from "01/wudata_01.xtc": Read 852472
05:00:14:WU01:FS01:0xa4:xtc file hash check passed.
05:00:14:WU01:FS01:0xa4:edr file hash check passed.
05:00:14:WU01:FS01:0xa4:logfile size: 23447
05:00:14:WU01:FS01:0xa4:Leaving Run
05:00:14:WU01:FS01:0xa4:- Writing 2289199 bytes of core data to disk...
05:00:15:WU01:FS01:0xa4:Done: 2288687 -> 2192999 (compressed to 95.8 percent)
05:00:15:WU01:FS01:0xa4:  ... Done.
05:00:15:WU01:FS01:0xa4:- Shutting down core
05:00:15:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
05:00:15:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:00:15:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8049 run:453 clone:5 gen:102 core:0xa4 unit:0x0000009f6652edcc5013335d90312056
05:00:15:WU01:FS01:Uploading 2.09MiB to 171.67.108.60
05:00:15:WU00:FS01:Starting
05:00:15:WU01:FS01:Connecting to 171.67.108.60:8080
05:00:15:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
05:00:15:WU00:FS01:Started FahCore on PID 1248
05:00:15:WU00:FS01:Core PID:3528
05:00:15:WU00:FS01:FahCore 0xa4 started
05:00:16:WU00:FS01:0xa4:
05:00:16:WU00:FS01:0xa4:*------------------------------*
05:00:16:WU00:FS01:0xa4:[email protected] Gromacs GB Core
05:00:16:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
05:00:16:WU00:FS01:0xa4:Preparing to commence simulation
05:00:16:WU00:FS01:0xa4:- Looking at optimizations...
05:00:16:WU00:FS01:0xa4:- Created dyn
05:00:16:WU00:FS01:0xa4:- Files status OK
05:00:16:WU00:FS01:0xa4:- Expanded 525486 -> 1190912 (decompressed 226.6 percent)
05:00:16:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525486 data_size=1190912, decompressed_data_size=1190912 diff=0
05:00:16:WU00:FS01:0xa4:- Digital signature verified
05:00:16:WU00:FS01:0xa4:Project: 8028 (Run 286, Clone 1, Gen 56)
05:00:16:WU00:FS01:0xa4:Assembly optimizations on if available.
05:00:16:WU00:FS01:0xa4:Entering M.D.
05:00:21:WU01:FS01:Upload 35.85%
05:00:22:WU00:FS01:0xa4:Mapping NT from 8 to 8
05:00:22:WU00:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
05:00:27:WU01:FS01:Upload 68.72%
05:00:33:WU01:FS01:Upload 100.00%
05:00:33:WU01:FS01:Upload complete
05:00:33:WU01:FS01:Server responded WORK_ACK (400)
05:00:33:WU01:FS01:Final credit estimate, 1057.00 points
05:00:33:WU01:FS01:Cleaning up
05:01:30:WU00:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
05:02:37:WU00:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
05:03:45:WU00:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
05:05:01:WU00:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
05:06:08:WU00:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
05:07:21:WU00:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
05:08:35:WU00:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
05:09:39:WU00:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
05:10:56:WU00:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
05:12:09:WU00:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
05:13:18:WU00:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
05:14:28:WU00:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
05:15:40:WU00:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
05:16:45:WU00:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
05:17:57:WU00:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
05:19:05:WU00:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
05:20:15:WU00:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
05:21:18:WU00:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
05:22:23:WU00:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
05:23:25:WU00:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
05:24:30:WU00:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
05:25:33:WU00:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
05:26:38:WU00:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
05:27:43:WU00:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
05:28:46:WU00:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
05:29:50:WU00:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
05:30:54:WU00:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
05:31:57:WU00:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
05:33:02:WU00:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
05:34:05:WU00:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
05:35:09:WU00:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
05:36:13:WU00:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
05:37:18:WU00:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
05:38:34:WU00:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
05:39:39:WU00:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
05:40:43:WU00:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
05:41:47:WU00:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
05:42:54:WU00:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
05:44:08:WU00:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
05:45:20:WU00:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
05:46:26:WU00:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
05:47:33:WU00:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
05:48:43:WU00:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
05:49:51:WU00:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
05:50:55:WU00:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
05:52:02:WU00:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
05:53:07:WU00:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
05:54:16:WU00:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
05:55:24:WU00:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
05:56:32:WU00:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
05:57:41:WU00:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
05:58:50:WU00:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
05:59:58:WU00:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
06:01:05:WU00:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
06:02:18:WU00:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
06:03:26:WU00:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
06:04:38:WU00:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
06:05:46:WU00:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
06:06:58:WU00:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
06:08:07:WU00:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
06:09:17:WU00:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
06:10:33:WU00:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
06:11:52:WU00:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
06:13:06:WU00:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
06:14:17:WU00:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
06:15:29:WU00:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
06:16:39:WU00:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
06:17:51:WU00:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
06:18:57:WU00:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
06:20:10:WU00:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
06:21:20:WU00:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
06:22:41:WU00:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
06:23:56:WU00:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
06:25:09:WU00:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
06:26:18:WU00:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
06:27:28:WU00:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
06:28:38:WU00:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
06:29:48:WU00:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
06:31:01:WU00:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
06:32:05:WU00:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
06:33:10:WU00:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
06:34:13:WU00:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
06:35:18:WU00:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
06:36:20:WU00:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
06:37:29:WU00:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
06:38:36:WU00:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
06:39:48:WU00:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
06:40:54:WU00:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
06:42:07:WU00:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
06:43:16:WU00:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
06:44:22:WU00:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
06:45:38:WU00:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
06:46:55:WU00:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
06:48:00:WU00:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
06:49:11:WU00:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
06:50:17:WU00:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
06:51:28:WU00:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
06:52:38:WU00:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
06:53:48:WU00:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
06:53:48:WU01:FS01:Connecting to assign3.stanford.edu:8080
06:53:48:WU01:FS01:News: Welcome to [email protected]
06:53:48:WU01:FS01:Assigned to work server 171.67.108.60
06:53:48:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
06:53:48:WU01:FS01:Connecting to 171.67.108.60:8080
06:53:50:WU01:FS01:Downloading 513.96KiB
06:53:50:WU01:FS01:Download complete
06:53:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8028 run:2181 clone:4 gen:67 core:0xa4 unit:0x000000806652edcc50e7967830d234b4
06:55:01:WU00:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
06:55:01:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
06:55:11:WU00:FS01:0xa4:
06:55:11:WU00:FS01:0xa4:Finished Work Unit:
06:55:11:WU00:FS01:0xa4:- Reading up to 771072 from "00/wudata_01.trr": Read 771072
06:55:11:WU00:FS01:0xa4:trr file hash check passed.
06:55:11:WU00:FS01:0xa4:- Reading up to 836608 from "00/wudata_01.xtc": Read 836608
06:55:11:WU00:FS01:0xa4:xtc file hash check passed.
06:55:11:WU00:FS01:0xa4:edr file hash check passed.
06:55:11:WU00:FS01:0xa4:logfile size: 26411
06:55:11:WU00:FS01:0xa4:Leaving Run
06:55:15:WU00:FS01:0xa4:- Writing 1642915 bytes of core data to disk...
06:55:15:WU00:FS01:0xa4:Done: 1642403 -> 1580607 (compressed to 96.2 percent)
06:55:15:WU00:FS01:0xa4:  ... Done.
06:55:15:WU00:FS01:0xa4:- Shutting down core
06:55:15:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
06:55:15:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:55:15:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8028 run:286 clone:1 gen:56 core:0xa4 unit:0x0000005c6652edcc50e78f78e51e0751
06:55:16:WU00:FS01:Uploading 1.51MiB to 171.67.108.60
06:55:16:WU01:FS01:Starting
06:55:16:WU00:FS01:Connecting to 171.67.108.60:8080
06:55:16:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
06:55:16:WU01:FS01:Started FahCore on PID 5492
06:55:16:WU01:FS01:Core PID:2844
06:55:16:WU01:FS01:FahCore 0xa4 started
06:55:16:WU01:FS01:0xa4:
06:55:16:WU01:FS01:0xa4:*------------------------------*
06:55:16:WU01:FS01:0xa4:[email protected] Gromacs GB Core
06:55:16:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:55:16:WU01:FS01:0xa4:Preparing to commence simulation
06:55:16:WU01:FS01:0xa4:- Looking at optimizations...
06:55:16:WU01:FS01:0xa4:- Created dyn
06:55:16:WU01:FS01:0xa4:- Files status OK
06:55:16:WU01:FS01:0xa4:- Expanded 525779 -> 1191776 (decompressed 226.6 percent)
06:55:16:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525779 data_size=1191776, decompressed_data_size=1191776 diff=0
06:55:16:WU01:FS01:0xa4:- Digital signature verified
06:55:16:WU01:FS01:0xa4:Project: 8028 (Run 2181, Clone 4, Gen 67)
06:55:16:WU01:FS01:0xa4:Assembly optimizations on if available.
06:55:16:WU01:FS01:0xa4:Entering M.D.
06:55:22:WU01:FS01:0xa4:Mapping NT from 8 to 8
06:55:22:WU01:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
06:55:27:WU00:FS01:Upload complete
06:55:27:WU00:FS01:Server responded WORK_ACK (400)
06:55:27:WU00:FS01:Final credit estimate, 1971.00 points
06:55:27:WU00:FS01:Cleaning up
06:56:39:WU01:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
06:57:56:WU01:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
06:58:49:FS01:Paused
06:58:49:FS01:Shutting core down
06:58:56:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:58:56:WU01:FS01:0xa4:[email protected] Core Shutdown: CLIENT_DIED
06:59:50:WARNING:FS01:Killing WU01
06:59:50:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
09:28:33:FS01:Unpaused
09:28:33:WU01:FS01:Starting
09:28:33:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
09:28:34:WU01:FS01:Started FahCore on PID 2152
09:28:34:WU01:FS01:Core PID:2064
09:28:34:WU01:FS01:FahCore 0xa4 started
09:28:34:WU01:FS01:0xa4:
09:28:34:WU01:FS01:0xa4:*------------------------------*
09:28:34:WU01:FS01:0xa4:[email protected] Gromacs GB Core
09:28:34:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:28:34:WU01:FS01:0xa4:Preparing to commence simulation
09:28:34:WU01:FS01:0xa4:- Looking at optimizations...
09:28:34:WU01:FS01:0xa4:- Files status OK
09:28:34:WU01:FS01:0xa4:- Expanded 525779 -> 1191776 (decompressed 226.6 percent)
09:28:34:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525779 data_size=1191776, decompressed_data_size=1191776 diff=0
09:28:34:WU01:FS01:0xa4:- Digital signature verified
09:28:34:WU01:FS01:0xa4:Project: 8028 (Run 2181, Clone 4, Gen 67)
09:28:34:WU01:FS01:0xa4:Assembly optimizations on if available.
09:28:34:WU01:FS01:0xa4:Entering M.D.
09:28:40:WU01:FS01:0xa4:Mapping NT from 8 to 8
09:28:40:WU01:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
09:29:46:WU01:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
09:30:51:WU01:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
09:31:58:WU01:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
09:33:03:WU01:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
09:34:07:WU01:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
09:35:13:WU01:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
09:36:19:WU01:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
09:37:22:WU01:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
09:38:22:WU01:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
09:39:21:WU01:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
09:40:23:WU01:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
09:41:25:WU01:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
09:42:25:WU01:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
09:43:25:WU01:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
09:44:27:WU01:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
09:45:28:WU01:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
09:46:29:WU01:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
09:47:30:WU01:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
09:48:31:WU01:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
09:49:32:WU01:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
09:50:34:WU01:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
09:51:37:WU01:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
09:52:51:WU01:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
09:53:54:WU01:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
09:54:55:WU01:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
09:55:58:WU01:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
09:57:02:WU01:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
09:58:04:WU01:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
09:59:12:WU01:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
10:00:17:WU01:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
10:01:22:WU01:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
10:02:24:WU01:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
10:03:28:WU01:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
10:04:34:WU01:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
10:05:42:WU01:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
10:06:45:WU01:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
10:07:49:WU01:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
10:08:54:WU01:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
10:09:56:WU01:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
10:10:59:WU01:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
10:12:12:WU01:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
10:13:30:WU01:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
10:14:34:WU01:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
10:15:43:WU01:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
10:16:45:WU01:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
10:17:57:WU01:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
10:19:11:WU01:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
10:20:23:WU01:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
10:21:44:WU01:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
10:22:50:WU01:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
10:23:58:WU01:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
10:25:10:WU01:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
10:26:17:WU01:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
10:27:35:WU01:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
10:28:37:WU01:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
10:29:44:WU01:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
10:30:58:WU01:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
10:32:10:WU01:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
10:33:22:WU01:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
10:34:39:WU01:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
10:36:03:WU01:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
10:37:23:WU01:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
10:38:40:WU01:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
10:39:51:WU01:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
10:41:09:WU01:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
10:42:19:WU01:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
10:43:23:WU01:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
10:44:32:WU01:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
10:45:44:WU01:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
10:46:52:WU01:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
10:47:53:WU01:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
10:48:54:WU01:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
10:49:54:WU01:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
10:50:55:WU01:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
10:51:55:WU01:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
10:52:55:WU01:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
10:53:57:WU01:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
10:54:57:WU01:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
10:55:59:WU01:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
10:56:59:WU01:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
10:58:01:WU01:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
10:59:01:WU01:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
11:00:02:WU01:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
11:01:04:WU01:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
11:02:04:WU01:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
11:03:06:WU01:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
11:04:06:WU01:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
11:05:08:WU01:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
11:06:08:WU01:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
11:07:10:WU01:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
11:08:10:WU01:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
11:09:13:WU01:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
11:10:13:WU01:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
11:11:15:WU01:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
11:12:14:WU01:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
11:13:16:WU01:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
11:14:15:WU01:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
11:15:17:WU01:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
11:16:18:WU01:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
11:16:19:WU00:FS01:Connecting to assign3.stanford.edu:8080
11:16:19:WU00:FS01:News: Welcome to [email protected]
11:16:19:WU00:FS01:Assigned to work server 171.67.108.60
11:16:19:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
11:16:19:WU00:FS01:Connecting to 171.67.108.60:8080
11:16:21:WU00:FS01:Downloading 513.27KiB
11:16:21:WU00:FS01:Download complete
11:16:21:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8028 run:2818 clone:2 gen:46 core:0xa4 unit:0x000000466652edcc50e798cb6a12dd37
11:17:18:WU01:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
11:17:18:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:17:28:WU01:FS01:0xa4:
11:17:28:WU01:FS01:0xa4:Finished Work Unit:
11:17:28:WU01:FS01:0xa4:- Reading up to 771720 from "01/wudata_01.trr": Read 771720
11:17:28:WU01:FS01:0xa4:trr file hash check passed.
11:17:28:WU01:FS01:0xa4:- Reading up to 837532 from "01/wudata_01.xtc": Read 837532
11:17:28:WU01:FS01:0xa4:xtc file hash check passed.
11:17:28:WU01:FS01:0xa4:edr file hash check passed.
11:17:28:WU01:FS01:0xa4:logfile size: 26376
11:17:28:WU01:FS01:0xa4:Leaving Run
11:17:33:WU01:FS01:0xa4:- Writing 1644452 bytes of core data to disk...
11:17:33:WU01:FS01:0xa4:Done: 1643940 -> 1582305 (compressed to 96.2 percent)
11:17:33:WU01:FS01:0xa4:  ... Done.
11:17:33:WU01:FS01:0xa4:- Shutting down core
11:17:33:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
11:17:34:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:17:34:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8028 run:2181 clone:4 gen:67 core:0xa4 unit:0x000000806652edcc50e7967830d234b4
11:17:34:WU01:FS01:Uploading 1.51MiB to 171.67.108.60
11:17:34:WU00:FS01:Starting
11:17:34:WU01:FS01:Connecting to 171.67.108.60:8080
11:17:34:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
11:17:34:WU00:FS01:Started FahCore on PID 5864
11:17:34:WU00:FS01:Core PID:6068
11:17:34:WU00:FS01:FahCore 0xa4 started
11:17:34:WU00:FS01:0xa4:
11:17:34:WU00:FS01:0xa4:*------------------------------*
11:17:34:WU00:FS01:0xa4:[email protected] Gromacs GB Core
11:17:34:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
11:17:34:WU00:FS01:0xa4:Preparing to commence simulation
11:17:34:WU00:FS01:0xa4:- Looking at optimizations...
11:17:34:WU00:FS01:0xa4:- Created dyn
11:17:34:WU00:FS01:0xa4:- Files status OK
11:17:34:WU00:FS01:0xa4:- Expanded 525078 -> 1190624 (decompressed 226.7 percent)
11:17:34:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525078 data_size=1190624, decompressed_data_size=1190624 diff=0
11:17:34:WU00:FS01:0xa4:- Digital signature verified
11:17:34:WU00:FS01:0xa4:Project: 8028 (Run 2818, Clone 2, Gen 46)
11:17:34:WU00:FS01:0xa4:Assembly optimizations on if available.
11:17:34:WU00:FS01:0xa4:Entering M.D.
11:17:40:WU00:FS01:0xa4:Mapping NT from 8 to 8
11:17:40:WU00:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
11:17:43:WU01:FS01:Upload complete
11:17:43:WU01:FS01:Server responded WORK_ACK (400)
11:17:43:WU01:FS01:Final credit estimate, 1303.00 points
11:17:43:WU01:FS01:Cleaning up
11:18:41:WU00:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
11:19:43:WU00:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
11:20:42:WU00:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
11:21:41:WU00:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
11:22:43:WU00:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
11:23:43:WU00:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
11:24:45:WU00:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
11:25:47:WU00:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
11:26:47:WU00:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
11:27:49:WU00:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
11:28:49:WU00:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
11:29:51:WU00:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
11:30:51:WU00:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
11:31:51:WU00:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
11:32:53:WU00:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
11:33:53:WU00:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
11:34:55:WU00:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
11:35:55:WU00:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
11:36:57:WU00:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
11:37:57:WU00:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
11:38:59:WU00:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
11:40:06:WU00:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
11:41:08:WU00:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
11:42:07:WU00:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
11:43:07:WU00:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
11:44:08:WU00:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
11:45:07:WU00:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
11:46:09:WU00:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
11:47:08:WU00:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
11:48:10:WU00:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
11:49:10:WU00:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
11:50:11:WU00:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
11:51:11:WU00:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
11:52:12:WU00:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
11:53:12:WU00:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
11:54:12:WU00:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
11:55:13:WU00:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
11:56:12:WU00:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
11:57:14:WU00:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
11:58:14:WU00:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
11:59:15:WU00:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
12:00:15:WU00:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
12:01:14:WU00:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
12:02:16:WU00:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
12:03:16:WU00:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
12:04:17:WU00:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
12:05:17:WU00:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
12:06:18:WU00:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
12:07:18:WU00:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
12:08:21:WU00:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
12:09:21:WU00:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
12:10:22:WU00:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
12:11:22:WU00:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
12:12:24:WU00:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
12:13:24:WU00:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
12:14:25:WU00:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
12:15:25:WU00:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
12:16:25:WU00:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
12:17:27:WU00:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
12:18:26:WU00:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
12:19:28:WU00:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
12:20:28:WU00:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
12:21:30:WU00:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
12:22:31:WU00:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
12:23:31:WU00:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
12:24:31:WU00:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
12:25:33:WU00:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
12:26:33:WU00:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
12:27:34:WU00:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
12:28:34:WU00:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
12:29:34:WU00:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
12:30:35:WU00:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
12:31:35:WU00:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
12:32:37:WU00:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
12:33:37:WU00:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
12:34:37:WU00:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
12:35:38:WU00:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
12:36:38:WU00:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
12:37:38:WU00:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
12:38:39:WU00:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
12:39:46:WU00:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
12:40:48:WU00:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
12:41:47:WU00:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
12:42:47:WU00:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
12:43:49:WU00:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
12:44:48:WU00:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
12:45:49:WU00:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
12:46:50:WU00:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
12:47:50:WU00:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
12:48:52:WU00:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
12:49:51:WU00:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
12:50:53:WU00:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
12:51:53:WU00:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
12:52:55:WU00:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
12:53:55:WU00:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
12:54:56:WU00:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
12:55:56:WU00:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
12:56:58:WU00:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
12:57:58:WU00:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
12:57:59:WU01:FS01:Connecting to assign3.stanford.edu:8080
12:58:20:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:58:20:WU01:FS01:Connecting to assign4.stanford.edu:80
12:58:21:WU01:FS01:News: Welcome to [email protected]
12:58:21:WU01:FS01:Assigned to work server 171.64.65.104
12:58:21:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.64.65.104
12:58:21:WU01:FS01:Connecting to 171.64.65.104:8080
12:58:22:WU01:FS01:Downloading 331.55KiB
12:58:22:WU01:FS01:Download complete
12:58:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:7611 run:0 clone:32 gen:335 core:0xa4 unit:0x000001e1664f2dd04df0f4a21201b246
12:58:22:WU01:FS01:Downloading project 7611 description
12:58:22:WU01:FS01:Connecting to fah-web.stanford.edu:80
12:58:23:WU01:FS01:Project 7611 description downloaded successfully
12:59:00:WU00:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
12:59:00:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:59:10:WU00:FS01:0xa4:
12:59:10:WU00:FS01:0xa4:Finished Work Unit:
12:59:10:WU00:FS01:0xa4:- Reading up to 770856 from "00/wudata_01.trr": Read 770856
12:59:10:WU00:FS01:0xa4:trr file hash check passed.
12:59:10:WU00:FS01:0xa4:- Reading up to 836500 from "00/wudata_01.xtc": Read 836500
12:59:10:WU00:FS01:0xa4:xtc file hash check passed.
12:59:10:WU00:FS01:0xa4:edr file hash check passed.
12:59:10:WU00:FS01:0xa4:logfile size: 26343
12:59:10:WU00:FS01:0xa4:Leaving Run
12:59:13:WU00:FS01:0xa4:- Writing 1642523 bytes of core data to disk...
12:59:13:WU00:FS01:0xa4:Done: 1642011 -> 1580269 (compressed to 96.2 percent)
12:59:13:WU00:FS01:0xa4:  ... Done.
12:59:13:WU00:FS01:0xa4:- Shutting down core
12:59:13:WU00:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
12:59:14:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:59:14:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8028 run:2818 clone:2 gen:46 core:0xa4 unit:0x000000466652edcc50e798cb6a12dd37
12:59:14:WU00:FS01:Uploading 1.51MiB to 171.67.108.60
12:59:14:WU01:FS01:Starting
12:59:14:WU00:FS01:Connecting to 171.67.108.60:8080
12:59:14:WU01:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
12:59:14:WU01:FS01:Started FahCore on PID 6108
12:59:14:WU01:FS01:Core PID:5664
12:59:14:WU01:FS01:FahCore 0xa4 started
12:59:14:WU01:FS01:0xa4:
12:59:14:WU01:FS01:0xa4:*------------------------------*
12:59:14:WU01:FS01:0xa4:[email protected] Gromacs GB Core
12:59:14:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:59:14:WU01:FS01:0xa4:Preparing to commence simulation
12:59:14:WU01:FS01:0xa4:- Looking at optimizations...
12:59:14:WU01:FS01:0xa4:- Created dyn
12:59:14:WU01:FS01:0xa4:- Files status OK
12:59:14:WU01:FS01:0xa4:- Expanded 338991 -> 644556 (decompressed 190.1 percent)
12:59:14:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=338991 data_size=644556, decompressed_data_size=644556 diff=0
12:59:14:WU01:FS01:0xa4:- Digital signature verified
12:59:14:WU01:FS01:0xa4:Project: 7611 (Run 0, Clone 32, Gen 335)
12:59:14:WU01:FS01:0xa4:Assembly optimizations on if available.
12:59:14:WU01:FS01:0xa4:Entering M.D.
12:59:20:WU01:FS01:0xa4:Mapping NT from 8 to 8
12:59:20:WU01:FS01:0xa4:Completed 0 out of 2000000 steps  (0%)
12:59:23:WU00:FS01:Upload complete
12:59:23:WU00:FS01:Server responded WORK_ACK (400)
12:59:23:WU00:FS01:Final credit estimate, 2086.00 points
12:59:23:WU00:FS01:Cleaning up
13:04:40:WU01:FS01:0xa4:Completed 20000 out of 2000000 steps  (1%)
13:10:13:WU01:FS01:0xa4:Completed 40000 out of 2000000 steps  (2%)
13:15:45:WU01:FS01:0xa4:Completed 60000 out of 2000000 steps  (3%)
13:21:06:WU01:FS01:0xa4:Completed 80000 out of 2000000 steps  (4%)
13:26:37:WU01:FS01:0xa4:Completed 100000 out of 2000000 steps  (5%)
13:32:12:WU01:FS01:0xa4:Completed 120000 out of 2000000 steps  (6%)
13:37:44:WU01:FS01:0xa4:Completed 140000 out of 2000000 steps  (7%)
13:43:19:WU01:FS01:0xa4:Completed 160000 out of 2000000 steps  (8%)
13:48:58:WU01:FS01:0xa4:Completed 180000 out of 2000000 steps  (9%)
13:54:30:WU01:FS01:0xa4:Completed 200000 out of 2000000 steps  (10%)
13:59:54:WU01:FS01:0xa4:Completed 220000 out of 2000000 steps  (11%)
14:05:42:WU01:FS01:0xa4:Completed 240000 out of 2000000 steps  (12%)
14:11:36:WU01:FS01:0xa4:Completed 260000 out of 2000000 steps  (13%)
14:17:05:WU01:FS01:0xa4:Completed 280000 out of 2000000 steps  (14%)
14:22:35:WU01:FS01:0xa4:Completed 300000 out of 2000000 steps  (15%)
14:28:00:WU01:FS01:0xa4:Completed 320000 out of 2000000 steps  (16%)
14:33:37:WU01:FS01:0xa4:Completed 340000 out of 2000000 steps  (17%)
14:39:06:WU01:FS01:0xa4:Completed 360000 out of 2000000 steps  (18%)
14:44:33:WU01:FS01:0xa4:Completed 380000 out of 2000000 steps  (19%)
14:49:59:WU01:FS01:0xa4:Completed 400000 out of 2000000 steps  (20%)
14:55:33:WU01:FS01:0xa4:Completed 420000 out of 2000000 steps  (21%)
15:01:05:WU01:FS01:0xa4:Completed 440000 out of 2000000 steps  (22%)
15:06:39:WU01:FS01:0xa4:Completed 460000 out of 2000000 steps  (23%)
15:12:19:WU01:FS01:0xa4:Completed 480000 out of 2000000 steps  (24%)
15:17:49:WU01:FS01:0xa4:Completed 500000 out of 2000000 steps  (25%)
15:23:29:WU01:FS01:0xa4:Completed 520000 out of 2000000 steps  (26%)
15:29:06:WU01:FS01:0xa4:Completed 540000 out of 2000000 steps  (27%)
15:34:56:WU01:FS01:0xa4:Completed 560000 out of 2000000 steps  (28%)
15:40:53:WU01:FS01:0xa4:Completed 580000 out of 2000000 steps  (29%)
15:46:34:WU01:FS01:0xa4:Completed 600000 out of 2000000 steps  (30%)
15:52:12:WU01:FS01:0xa4:Completed 620000 out of 2000000 steps  (31%)
15:57:56:WU01:FS01:0xa4:Completed 640000 out of 2000000 steps  (32%)
16:03:37:WU01:FS01:0xa4:Completed 660000 out of 2000000 steps  (33%)
16:09:23:WU01:FS01:0xa4:Completed 680000 out of 2000000 steps  (34%)
16:15:08:WU01:FS01:0xa4:Completed 700000 out of 2000000 steps  (35%)
16:21:01:WU01:FS01:0xa4:Completed 720000 out of 2000000 steps  (36%)
16:26:36:WU01:FS01:0xa4:Completed 740000 out of 2000000 steps  (37%)
16:32:27:WU01:FS01:0xa4:Completed 760000 out of 2000000 steps  (38%)
16:38:03:WU01:FS01:0xa4:Completed 780000 out of 2000000 steps  (39%)
16:43:57:WU01:FS01:0xa4:Completed 800000 out of 2000000 steps  (40%)
16:49:31:WU01:FS01:0xa4:Completed 820000 out of 2000000 steps  (41%)
16:54:56:WU01:FS01:0xa4:Completed 840000 out of 2000000 steps  (42%)
17:00:24:WU01:FS01:0xa4:Completed 860000 out of 2000000 steps  (43%)
17:05:49:WU01:FS01:0xa4:Completed 880000 out of 2000000 steps  (44%)
17:11:14:WU01:FS01:0xa4:Completed 900000 out of 2000000 steps  (45%)
17:16:31:WU01:FS01:0xa4:Completed 920000 out of 2000000 steps  (46%)
17:21:54:WU01:FS01:0xa4:Completed 940000 out of 2000000 steps  (47%)
17:27:33:WU01:FS01:0xa4:Completed 960000 out of 2000000 steps  (48%)
17:33:02:WU01:FS01:0xa4:Completed 980000 out of 2000000 steps  (49%)
17:38:51:WU01:FS01:0xa4:Completed 1000000 out of 2000000 steps  (50%)
17:44:34:WU01:FS01:0xa4:Completed 1020000 out of 2000000 steps  (51%)
17:50:10:WU01:FS01:0xa4:Completed 1040000 out of 2000000 steps  (52%)
17:55:46:WU01:FS01:0xa4:Completed 1060000 out of 2000000 steps  (53%)
18:01:35:WU01:FS01:0xa4:Completed 1080000 out of 2000000 steps  (54%)
18:07:16:WU01:FS01:0xa4:Completed 1100000 out of 2000000 steps  (55%)
18:12:57:WU01:FS01:0xa4:Completed 1120000 out of 2000000 steps  (56%)
18:18:47:WU01:FS01:0xa4:Completed 1140000 out of 2000000 steps  (57%)
18:24:40:WU01:FS01:0xa4:Completed 1160000 out of 2000000 steps  (58%)
18:30:23:WU01:FS01:0xa4:Completed 1180000 out of 2000000 steps  (59%)
18:35:46:WU01:FS01:0xa4:Completed 1200000 out of 2000000 steps  (60%)
18:41:44:WU01:FS01:0xa4:Completed 1220000 out of 2000000 steps  (61%)
18:47:24:WU01:FS01:0xa4:Completed 1240000 out of 2000000 steps  (62%)
18:53:02:WU01:FS01:0xa4:Completed 1260000 out of 2000000 steps  (63%)
18:58:40:WU01:FS01:0xa4:Completed 1280000 out of 2000000 steps  (64%)
19:04:15:WU01:FS01:0xa4:Completed 1300000 out of 2000000 steps  (65%)
19:09:45:WU01:FS01:0xa4:Completed 1320000 out of 2000000 steps  (66%)
19:15:20:WU01:FS01:0xa4:Completed 1340000 out of 2000000 steps  (67%)
19:20:58:WU01:FS01:0xa4:Completed 1360000 out of 2000000 steps  (68%)
19:26:36:WU01:FS01:0xa4:Completed 1380000 out of 2000000 steps  (69%)
19:32:19:WU01:FS01:0xa4:Completed 1400000 out of 2000000 steps  (70%)
19:37:55:WU01:FS01:0xa4:Completed 1420000 out of 2000000 steps  (71%)
19:44:46:WU01:FS01:0xa4:Completed 1440000 out of 2000000 steps  (72%)
19:50:39:WU01:FS01:0xa4:Completed 1460000 out of 2000000 steps  (73%)
19:56:30:WU01:FS01:0xa4:Completed 1480000 out of 2000000 steps  (74%)
20:02:36:WU01:FS01:0xa4:Completed 1500000 out of 2000000 steps  (75%)
20:08:55:WU01:FS01:0xa4:Completed 1520000 out of 2000000 steps  (76%)
20:14:41:WU01:FS01:0xa4:Completed 1540000 out of 2000000 steps  (77%)
20:20:33:WU01:FS01:0xa4:Completed 1560000 out of 2000000 steps  (78%)
20:26:15:WU01:FS01:0xa4:Completed 1580000 out of 2000000 steps  (79%)
20:31:53:WU01:FS01:0xa4:Completed 1600000 out of 2000000 steps  (80%)
20:37:50:WU01:FS01:0xa4:Completed 1620000 out of 2000000 steps  (81%)
20:43:41:WU01:FS01:0xa4:Completed 1640000 out of 2000000 steps  (82%)
20:49:25:WU01:FS01:0xa4:Completed 1660000 out of 2000000 steps  (83%)
20:55:26:WU01:FS01:0xa4:Completed 1680000 out of 2000000 steps  (84%)
21:01:41:WU01:FS01:0xa4:Completed 1700000 out of 2000000 steps  (85%)
21:07:55:WU01:FS01:0xa4:Completed 1720000 out of 2000000 steps  (86%)
21:13:57:WU01:FS01:0xa4:Completed 1740000 out of 2000000 steps  (87%)
21:20:04:WU01:FS01:0xa4:Completed 1760000 out of 2000000 steps  (88%)
21:26:30:WU01:FS01:0xa4:Completed 1780000 out of 2000000 steps  (89%)
21:32:31:WU01:FS01:0xa4:Completed 1800000 out of 2000000 steps  (90%)
21:38:45:WU01:FS01:0xa4:Completed 1820000 out of 2000000 steps  (91%)
21:44:27:WU01:FS01:0xa4:Completed 1840000 out of 2000000 steps  (92%)
21:50:19:WU01:FS01:0xa4:Completed 1860000 out of 2000000 steps  (93%)
21:56:03:WU01:FS01:0xa4:Completed 1880000 out of 2000000 steps  (94%)
22:01:45:WU01:FS01:0xa4:Completed 1900000 out of 2000000 steps  (95%)
22:07:23:WU01:FS01:0xa4:Completed 1920000 out of 2000000 steps  (96%)
22:13:27:WU01:FS01:0xa4:Completed 1940000 out of 2000000 steps  (97%)
22:19:20:WU01:FS01:0xa4:Completed 1960000 out of 2000000 steps  (98%)
22:25:54:WU01:FS01:0xa4:Completed 1980000 out of 2000000 steps  (99%)
22:25:55:WU00:FS01:Connecting to assign3.stanford.edu:8080
22:25:55:WU00:FS01:News: Welcome to [email protected]
22:25:55:WU00:FS01:Assigned to work server 171.67.108.60
22:25:55:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.60
22:25:55:WU00:FS01:Connecting to 171.67.108.60:8080
22:25:57:WU00:FS01:Downloading 513.47KiB
22:25:57:WU00:FS01:Download complete
22:25:57:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8028 run:782 clone:0 gen:53 core:0xa4 unit:0x0000004e6652edcc50e7914cb67f4ae6
22:31:53:WU01:FS01:0xa4:Completed 2000000 out of 2000000 steps  (100%)
22:31:53:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:32:03:WU01:FS01:0xa4:
22:32:03:WU01:FS01:0xa4:Finished Work Unit:
22:32:03:WU01:FS01:0xa4:- Reading up to 488544 from "01/wudata_01.trr": Read 488544
22:32:03:WU01:FS01:0xa4:trr file hash check passed.
22:32:03:WU01:FS01:0xa4:- Reading up to 57568 from "01/wudata_01.xtc": Read 57568
22:32:03:WU01:FS01:0xa4:xtc file hash check passed.
22:32:03:WU01:FS01:0xa4:edr file hash check passed.
22:32:03:WU01:FS01:0xa4:logfile size: 40306
22:32:03:WU01:FS01:0xa4:Leaving Run
22:32:07:WU01:FS01:0xa4:- Writing 610334 bytes of core data to disk...
22:32:07:WU01:FS01:0xa4:Done: 609822 -> 547144 (compressed to 89.7 percent)
22:32:07:WU01:FS01:0xa4:  ... Done.
22:32:07:WU01:FS01:0xa4:- Shutting down core
22:32:07:WU01:FS01:0xa4:[email protected] Core Shutdown: FINISHED_UNIT
22:32:07:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:32:08:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:7611 run:0 clone:32 gen:335 core:0xa4 unit:0x000001e1664f2dd04df0f4a21201b246
22:32:08:WU01:FS01:Uploading 534.82KiB to 171.64.65.104
22:32:08:WU00:FS01:Starting
22:32:08:WU01:FS01:Connecting to 171.64.65.104:8080
22:32:08:WU00:FS01:Running FahCore: E:\Backups\FAHClient/FAHCoreWrapper.exe E:/Backups/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2200 -checkpoint 15 -np 8
22:32:08:WU00:FS01:Started FahCore on PID 5192
22:32:08:WU00:FS01:Core PID:5080
22:32:08:WU00:FS01:FahCore 0xa4 started
22:32:08:WU00:FS01:0xa4:
22:32:08:WU00:FS01:0xa4:*------------------------------*
22:32:08:WU00:FS01:0xa4:[email protected] Gromacs GB Core
22:32:08:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
22:32:08:WU00:FS01:0xa4:Preparing to commence simulation
22:32:08:WU00:FS01:0xa4:- Looking at optimizations...
22:32:08:WU00:FS01:0xa4:- Created dyn
22:32:08:WU00:FS01:0xa4:- Files status OK
22:32:08:WU00:FS01:0xa4:- Expanded 525286 -> 1191056 (decompressed 226.7 percent)
22:32:08:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525286 data_size=1191056, decompressed_data_size=1191056 diff=0
22:32:08:WU00:FS01:0xa4:- Digital signature verified
22:32:08:WU00:FS01:0xa4:Project: 8028 (Run 782, Clone 0, Gen 53)
22:32:08:WU00:FS01:0xa4:Assembly optimizations on if available.
22:32:08:WU00:FS01:0xa4:Entering M.D.
22:32:11:WU01:FS01:Upload complete
22:32:11:WU01:FS01:Server responded WORK_ACK (400)
22:32:11:WU01:FS01:Final credit estimate, 8485.00 points
22:32:11:WU01:FS01:Cleaning up
22:32:14:WU00:FS01:0xa4:Mapping NT from 8 to 8
22:32:14:WU00:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
22:33:18:WU00:FS01:0xa4:Completed 5000 out of 500000 steps  (1%)
22:34:28:WU00:FS01:0xa4:Completed 10000 out of 500000 steps  (2%)
22:35:37:WU00:FS01:0xa4:Completed 15000 out of 500000 steps  (3%)
22:36:46:WU00:FS01:0xa4:Completed 20000 out of 500000 steps  (4%)
22:37:50:WU00:FS01:0xa4:Completed 25000 out of 500000 steps  (5%)
22:39:02:WU00:FS01:0xa4:Completed 30000 out of 500000 steps  (6%)
22:40:16:WU00:FS01:0xa4:Completed 35000 out of 500000 steps  (7%)
22:41:28:WU00:FS01:0xa4:Completed 40000 out of 500000 steps  (8%)
22:42:42:WU00:FS01:0xa4:Completed 45000 out of 500000 steps  (9%)
22:43:53:WU00:FS01:0xa4:Completed 50000 out of 500000 steps  (10%)
22:45:16:WU00:FS01:0xa4:Completed 55000 out of 500000 steps  (11%)
22:46:40:WU00:FS01:0xa4:Completed 60000 out of 500000 steps  (12%)
22:47:53:WU00:FS01:0xa4:Completed 65000 out of 500000 steps  (13%)
22:49:00:WU00:FS01:0xa4:Completed 70000 out of 500000 steps  (14%)
22:49:12:FS01:Finishing
22:50:07:WU00:FS01:0xa4:Completed 75000 out of 500000 steps  (15%)
22:51:11:WU00:FS01:0xa4:Completed 80000 out of 500000 steps  (16%)
22:52:19:WU00:FS01:0xa4:Completed 85000 out of 500000 steps  (17%)
22:53:34:WU00:FS01:0xa4:Completed 90000 out of 500000 steps  (18%)
22:54:43:WU00:FS01:0xa4:Completed 95000 out of 500000 steps  (19%)
22:55:54:WU00:FS01:0xa4:Completed 100000 out of 500000 steps  (20%)
22:57:00:WU00:FS01:0xa4:Completed 105000 out of 500000 steps  (21%)
22:58:10:WU00:FS01:0xa4:Completed 110000 out of 500000 steps  (22%)
22:59:22:WU00:FS01:0xa4:Completed 115000 out of 500000 steps  (23%)
23:00:30:WU00:FS01:0xa4:Completed 120000 out of 500000 steps  (24%)
23:01:36:WU00:FS01:0xa4:Completed 125000 out of 500000 steps  (25%)
23:02:42:WU00:FS01:0xa4:Completed 130000 out of 500000 steps  (26%)
23:03:51:WU00:FS01:0xa4:Completed 135000 out of 500000 steps  (27%)
23:05:01:WU00:FS01:0xa4:Completed 140000 out of 500000 steps  (28%)
23:06:16:WU00:FS01:0xa4:Completed 145000 out of 500000 steps  (29%)
23:07:29:WU00:FS01:0xa4:Completed 150000 out of 500000 steps  (30%)
23:08:47:WU00:FS01:0xa4:Completed 155000 out of 500000 steps  (31%)
23:09:58:WU00:FS01:0xa4:Completed 160000 out of 500000 steps  (32%)
23:11:08:WU00:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
23:12:10:WU00:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
23:13:14:WU00:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
23:14:21:WU00:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
23:15:30:WU00:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
23:16:35:WU00:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
23:17:45:WU00:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
23:18:47:WU00:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
23:19:56:WU00:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
23:21:02:WU00:FS01:0xa4:Completed 210000 out of 500000 steps  (42%)
23:22:13:WU00:FS01:0xa4:Completed 215000 out of 500000 steps  (43%)
23:23:21:WU00:FS01:0xa4:Completed 220000 out of 500000 steps  (44%)
23:24:27:WU00:FS01:0xa4:Completed 225000 out of 500000 steps  (45%)
23:25:33:WU00:FS01:0xa4:Completed 230000 out of 500000 steps  (46%)
23:26:38:WU00:FS01:0xa4:Completed 235000 out of 500000 steps  (47%)
23:27:48:WU00:FS01:0xa4:Completed 240000 out of 500000 steps  (48%)
23:28:58:WU00:FS01:0xa4:Completed 245000 out of 500000 steps  (49%)
23:30:07:WU00:FS01:0xa4:Completed 250000 out of 500000 steps  (50%)
23:31:10:WU00:FS01:0xa4:Completed 255000 out of 500000 steps  (51%)
23:32:15:WU00:FS01:0xa4:Completed 260000 out of 500000 steps  (52%)
23:33:25:WU00:FS01:0xa4:Completed 265000 out of 500000 steps  (53%)
23:34:30:WU00:FS01:0xa4:Completed 270000 out of 500000 steps  (54%)
23:35:38:WU00:FS01:0xa4:Completed 275000 out of 500000 steps  (55%)
23:36:45:WU00:FS01:0xa4:Completed 280000 out of 500000 steps  (56%)
23:37:50:WU00:FS01:0xa4:Completed 285000 out of 500000 steps  (57%)
23:39:01:WU00:FS01:0xa4:Completed 290000 out of 500000 steps  (58%)
23:40:15:WU00:FS01:0xa4:Completed 295000 out of 500000 steps  (59%)
23:41:25:WU00:FS01:0xa4:Completed 300000 out of 500000 steps  (60%)
23:42:56:WU00:FS01:0xa4:Completed 305000 out of 500000 steps  (61%)
23:44:03:WU00:FS01:0xa4:Completed 310000 out of 500000 steps  (62%)
23:45:07:WU00:FS01:0xa4:Completed 315000 out of 500000 steps  (63%)
23:46:11:WU00:FS01:0xa4:Completed 320000 out of 500000 steps  (64%)
23:47:15:WU00:FS01:0xa4:Completed 325000 out of 500000 steps  (65%)
23:48:20:WU00:FS01:0xa4:Completed 330000 out of 500000 steps  (66%)
23:49:37:WU00:FS01:0xa4:Completed 335000 out of 500000 steps  (67%)
23:50:52:WU00:FS01:0xa4:Completed 340000 out of 500000 steps  (68%)
23:52:01:WU00:FS01:0xa4:Completed 345000 out of 500000 steps  (69%)
23:53:12:WU00:FS01:0xa4:Completed 350000 out of 500000 steps  (70%)
23:54:21:WU00:FS01:0xa4:Completed 355000 out of 500000 steps  (71%)
23:55:30:WU00:FS01:0xa4:Completed 360000 out of 500000 steps  (72%)
23:56:41:WU00:FS01:0xa4:Completed 365000 out of 500000 steps  (73%)
23:57:51:WU00:FS01:0xa4:Completed 370000 out of 500000 steps  (74%)
23:59:01:WU00:FS01:0xa4:Completed 375000 out of 500000 steps  (75%)
00:00:13:WU00:FS01:0xa4:Completed 380000 out of 500000 steps  (76%)
00:01:26:WU00:FS01:0xa4:Completed 385000 out of 500000 steps  (77%)
00:02:33:WU00:FS01:0xa4:Completed 390000 out of 500000 steps  (78%)
00:03:38:WU00:FS01:0xa4:Completed 395000 out of 500000 steps  (79%)
00:04:40:WU00:FS01:0xa4:Completed 400000 out of 500000 steps  (80%)
00:05:46:WU00:FS01:0xa4:Completed 405000 out of 500000 steps  (81%)
00:06:51:WU00:FS01:0xa4:Completed 410000 out of 500000 steps  (82%)
00:07:54:WU00:FS01:0xa4:Completed 415000 out of 500000 steps  (83%)
00:09:03:WU00:FS01:0xa4:Completed 420000 out of 500000 steps  (84%)
00:10:08:WU00:FS01:0xa4:Completed 425000 out of 500000 steps  (85%)
00:11:13:WU00:FS01:0xa4:Completed 430000 out of 500000 steps  (86%)
00:12:19:WU00:FS01:0xa4:Completed 435000 out of 500000 steps  (87%)
00:13:22:WU00:FS01:0xa4:Completed 440000 out of 500000 steps  (88%)
00:14:27:WU00:FS01:0xa4:Completed 445000 out of 500000 steps  (89%)
00:15:30:WU00:FS01:0xa4:Completed 450000 out of 500000 steps  (90%)
00:16:36:WU00:FS01:0xa4:Completed 455000 out of 500000 steps  (91%)
00:17:40:WU00:FS01:0xa4:Completed 460000 out of 500000 steps  (92%)
00:18:45:WU00:FS01:0xa4:Completed 465000 out of 500000 steps  (93%)
00:19:51:WU00:FS01:0xa4:Completed 470000 out of 500000 steps  (94%)
00:20:54:WU00:FS01:0xa4:Completed 475000 out of 500000 steps  (95%)
00:22:00:WU00:FS01:0xa4:Completed 480000 out of 500000 steps  (96%)
00:23:04:WU00:FS01:0xa4:Completed 485000 out of 500000 steps  (97%)
00:24:09:WU00:FS01:0xa4:Completed 490000 out of 500000 steps  (98%)
00:25:16:WU00:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
00:26:23:WU00:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
00:26:24:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:26:34:WU00:FS01:0xa4:
00:26:34:WU00:FS01:0xa4:Finished Work Unit:
00:26:34:WU00:FS01:0xa4:- Reading up to 771180 from "00/wudata_01.trr": Read 771180
00:26:34:WU00:FS01:0xa4:trr file hash check passed.
00:26:34:WU00:FS01:0xa4:- Reading up to 837020 from "00/wudata_01.xtc": Read 837020
00:26:34:WU00:FS01:0xa4:xtc file hash check passed.
00:26:34:WU00:FS01:0xa4:edr file hash check passed.
00:26:34:WU00:FS01:0xa4:logfile size: 26409
00:26:34:WU00:FS01:0xa4:Leaving Run
00:26:37:WU00:FS01:0xa4:- Writing 1643433 bytes of core data to disk...
00:26:37:WU00:FS01:0xa4:Done: 1642921 -> 1581128 (compressed to 96.2 percent)
00:26:37:WU00:FS01:0xa4:  ... Done.
00:26:38:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:26:38:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8028 run:782 clone:0 gen:53 core:0xa4 unit:0x0000004e6652edcc50e7914cb67f4ae6
00:26:38:WU00:FS01:Uploading 1.51MiB to 171.67.108.60
00:26:38:WU00:FS01:Connecting to 171.67.108.60:8080
00:26:48:WU00:FS01:Upload complete
00:26:48:WU00:FS01:Server responded WORK_ACK (400)
00:26:48:WU00:FS01:Final credit estimate, 1926.00 points
00:26:48:WU00:FS01:Cleaning up
Originally Posted by SmokinWaffle View Post
Don't pause the client, then.
But how am I supposed to play the interwebz tanks.
Originally Posted by Atomfix View Post
Get the pitchforks out! We are going to Stanford University!
lol
Wait until you finish the work unit you're currently working on (by clicking finish instead of pause), then uninstall the client and when it asks you if you want to retain the configuration settings tell it no uninstall everything, then try a fresh install and see how that does.
Discussion Starter · #9 ·
Will do. I'm going to be increasing my overclock over the next 24 hours because I just don't feel 4.5ghz is enough.
It's never enough.
I would recommend holding off on increasing the OC until you can pinpoint your current problem or verify that the reinstall completely fixes it, so as to keep variables to a minimum. Nothing worse than trying to troubleshoot an existing problem and not knowing if it's your OC, or vice-verse trying to get stable on a new OC and not knowing if a problem is a preexisting one or if it's related to the new OC.
Best of luck with the higher OC though when the time comes.
Discussion Starter · #11 ·
It's never enough.
It did it at stock also so I'm glad my overclock was pretty darn stable.
What I'm going to do is just see if 4.7ghz will work. I'm then going to uninstall and then reinstall the [email protected] client. Right now I'm at 4.7ghz and so far in Prime 95 after an hour everything is looking good. Max of 75c on the cpu at 1.4 vcore.
One thing I have noticed though is that my motherboard VRM temp sensor broke on a restart.
Thanks Juano
Discussion Starter · #13 ·
Originally Posted by mmonnin View Post
I don't see a problem besides a pause and then it going back to the last checkpoint. You can partially fix this by changing the checkpoint value to be quicker so you lose less work.
You are completely correct.
Still... Why would it say killing WU? Makes me think it's dumping it and grabbing a new one. I'm still going to reinstall though as it's still the same client from when I was using my C2D about 2 years ago lol.
Forgive my blindness.
· Premium Member
Dunno. I just paused/unpaused and it doesn't say that.
13:17:31:WU01:FS00:0xa3:Completed 550000 out of 1000000 steps (55%)
13:22:25:FS00:paused
13:22:25:FS00:Shutting core down
13:22:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:22:44:FS00:Unpaused
13:22:45:WU01:FS00:Starting
Whats verbosity at?
Discussion Starter · #15 ·
Whats verbosity at?
I reinstalled and everything is perfectly fine. Can't find the log though
Verbosity was at standard. I never changed it.
1 - 15 of 15 Posts
