I love ThermalTake :D
433 6
As some of you know, i have been asking question about the TT BT (Big Typhoon).
This thing is a pain to install, with those little nuts n bolts in the hard to reach places. It took me about an hour to install and now my cpu is @ 39c idle with room to improve.
Next Thing To Do:
Now i want to cut out this flower design on my Enermax case and make it one big plexi window.
My only problem/question is when i do this mod, should i buy a 12cm fan and put it on that hole or should i leave the hole as is?
See Pics Below
1 - 7 of 7 Posts
I would say go for the fan. just make sure it matches and undervolt it if you can
i would... it will help with airflow a little...and drop temps even more.... so i say yes go for, and if not then us some air ducting to have the same effect...
Discussion Starter · #6 ·
Originally Posted by Marshall82
I did something very silimar but I just made an 80mm hole bigger ti fit a 120 mm fan. Go for it you see a great drop in temps.
I would, but my 80mm hole is in the middle and putting a 120mm would make a corner of the new fan blow into, or suck air out from the Bt
1 - 7 of 7 Posts
