I love ubuntu.
1659 Views 36 Replies 14 Participants Last post by  Bluescreen_Of_Death
I really do.
Wine works so well.
Im moving completely away from windows next week.
Wish me luck.
1 - 20 of 37 Posts
What about gaming?
Crossfired 4890s will miss it
Originally Posted by Daney View Post
What about gaming?
Wine.
FTW
it supports all of my games!
that I play...
only issue i have is Xfire (the program)
On my test rig that i have been fiddling around on, i cant seem to get Xfire to work without crashing.
I put ubuntu on my rig one day I didn't really like it, I don't think I gave it much of a chance though I might try it again some time when I'm really bored in the holidays If i can't get a job in a computer shop
takes some time to get used to.
Took me about a week to finally figure out how to start doing anything.
Out of curiousity, have you gotten L4D/L4D2 to work in Ubuntu?
I run on Ubuntu for 2 years! great OS and as long as you do not MESS with anything (like I did), you should be fine.
Yes, Yes I have. both of them work flawlessly. Check out this place for apps that work under WINE. Here.
I have had my fair share of reinstalls
O-o How about 11 reinstalls in a 2 year time period?
this past week ive been through 8 reinstalls.
Damn That sucks. How much data have you lost in a single reinstall (me it was 40GB which was a lot for me back then)
none, since im using a secondary computer :V
lol
Almost 2 years for me without windows (only in virtual box) on my main pc. I don't game tho'. But i've tinkered around with alot.... thing i like is since i have a seperate drive for my /home drive, when i want to reload, i just blow away my OS drive, reload and everything is still there. I gotta load a couple of programs but for the most part it is ready to go... I really like ubuntu... none of the headaches of spyware and malware and viruses...
why do you have a i386 install when your on a amd chip?
lol
Um, because i386 is 32-bit. AMD-64 is 64-bit so :/ If you want 32-bit you use i386 and AMD-64 if you 64-bit.
Reason - Intel owns 32-bit so it is i386
AMD owns 64-bit so it is AMD-64
lol
Cause i'm lazy and don't want to mess with flash to get it working properly. 64bit still doesn't work right with flash without a good deal of fiddling. If you like ubuntu, you should check out Ubuntu Ultimate... it is has a ton of stuff preloaded, i was running it for a while but wanted to check out the new 9.10.
http://ultimateedition.info/ultimate-edition-2-3/ I may go back to it again later but i had the 64bit one loaded and the flash stuff drove me nuts...
Use ubuntu Mint. Then you have NO issues
Use the Xfire plugin for Pidgin. Works a lot better, but doesn't detect the games you play, obviously.
1 - 20 of 37 Posts
