I might Upgrade to a 4870 if...
474 Views 11 Replies 11 Participants Last post by  FieryCoD
..my Cooler Master 550W can suport it. I know the 4870 needs 2X 6pin connectors from the PSU, mine currently only has 1. Would it work the current one + that Molex > 6pin adapter?
Tnx
1 - 12 of 12 Posts
you'll be fine
you should be fine
yay 4870 !
Will be OK. I have one that should be here today and I am going to power it with my 520.
I assume so about the wattage,
the molex to 6pin works for sure.
Yes it will work, Enjoy your 4870, I love mine!
Awsome! thx guys
yup it'll work. get a 1GB model tho. You won't regret it.
you should be fine.
go for it
1 - 12 of 12 Posts
