I need a cheap laptop with 3-4 hours battery life
728 Views 15 Replies 11 Participants Last post by  rustler753
I'd like to use it for taking notes at school, the only thing it needs to be able to do is run 1 Word document at a time and that's it. I have class for 3 hours straight so the battery needs to last at least 3 hours, preferably 3.5 just to make sure, although if replacement batteries are cheap I could just get another one and switch it out, so it'd only need to last about 2 hours.
I'd like to spend as little money as possible, ~$200 or less if possible. I think those mini laptops would be cool because they'd be easier to carry around. Also, I wouldn't mind buying used to get a good price. Any ideas?
1 - 16 of 16 Posts
for that price and that battery life, nothing. i get that battery life on my lappy, an asus, but it cost 350
Your best bet is a netbook. Dell was selling their Inspirion Mini 9's for <$200 recently. They claim a 4 hour battery life (you'll realistically get 3 hours). Currently they're $250 (for the Linux one), but you might be able to get a school discount.
One thing I don't understand is why companies are putting Windows on these netbooks. These netbooks are designed for word processing and browsing the web. Linux fits that task just as well as Windows, so don't be afraid of Linux if you've never used it before.
You could also look for a used standard-sized laptop, but sellers tend to sell their laptops for more than they are worth.
This thing isn't $200 but it's easily the best netbook on the market right now. They claim 9.5 hours battery life.
http://www.newegg.com/Product/Produc...82E16834220504
The cheapest that I've managed to find is the ASUS EeePC 4G (White) or ASUS EeePC 4G (Black) for $249.99 + $9.99 s/h at Amazon.com.
It comes with Xandros pre-installed with a simplified GUI framework on top of the usual Xandros desktop and OpenOffice installed (let's you create MS Office compatible documents). The only real downside is the 4 GB SSD drive. According to this review, it gets about 3 hours and 23 minutes of battery life (100% screen brightness, playing DiVX movie with 75% speaker volume).
You could spend another $26 and upgrade the RAM to 2 GB if you wanted to.
Alternatively, for $265.94 you can get the ASUS EeePC 900 (Black) instead. It already comes with a 20 GB SSD and 1 GB of RAM instead of 4 GB SSD and 512 MB of RAM (like on the 4G).
Battery life on the 900 is about 2 hours and 53 minutes (100% brightness + DiVX movie playing).
That Mini 9 looks like a good buy and the battery should last long enough. If it doesn't have Windows, can I still use Word, or some other software that can open and save .docs? or if I did later want to install Windows later, would it be able to handle it?
Nevermind, I tried a 9" Asus and it's way too small to type.
They come with OpenOffice.
and then if its too small, you're out of luck. They're all like that till you get to the 12 inchers.
My old Thinkad T41 will last about 3 hours running Office apps. You should be able to get one for right at $200.
You serious? It took me a day or so, but I got used to the 9" netbook keyboard and was able to touch-type at close to 40 WPM (my usual is 55).
Take a look at the 1000HE. The keyboard's isolated island-style keys should be better for you.
If not wait until the Samsung NC20 (12" screen, full-size keyboard) hits the U.S. in May/June for around $600.
I use the Asus 1000HE for school and it works great. I would recommend it.
the 10" netbooks have the closest keyboard to a fullsize board. its 90-95% the size of a fullsize keyboard.
i would go for one of the asus EEE netbooks. im considering getting one, probably will for class. just like you.
Are they keyboards on all the 9" laptops the same, or could the Asus one just be poorly designed versus the Dell's? I did try a 10" HP that I really liked but it was a little too expensive.
I've made due with the EEE 2GB Surf, and that's a 7".
I got an extra battery that lasts me 3.5-4 hours.
For the most part they are similar. The Mini 9's keyboard is the most cramped of all the 9" netbooks I've tried. Of the 9" ones, ASUS and Acer have amongst the 2nd best keyboards with HP being the "best" (that is if you can touch type on a flat surface).
At $375 (Amazon.com), the 1000HE is probably the one you'll like the best. More than enough battery life for taking notes, a Mackbook-like keyboard, and 92% of full-size.
I use mines for notes, entertainment, and web design + coding. I could go through about 6 hours of classes before the battery even begins to hit the 10% mark. I can easily type at my usual 50/55 WPM with few mistakes.
I enjoy my Asus N10J...its the "gaming" netbook. Not as expensive as real laptops and I can still get 6+ hours battery life, and still do solidworks/half life 2/left4dead when I choose.
1 - 16 of 16 Posts
