1 - 12 of 12 Posts
Discussion Starter #4
Originally Posted by 10acjed
I think thats a micro atx board.
Where are you located? US - UK - ?
im US
Discussion Starter #5
If US, something like this should suite you fine...
http://www.newegg.com/Product/Produc...82E16813128357
K i noticed w/ that one the
CPU Types are: Core 2 Quad / Core 2 Extreme / Core 2 Duo
is it backwards compatable w/ Pentium E2180
Discussion Starter #6
Originally Posted by morbid_bean View Post
how is this one? http://www.tigerdirect.com/applicati...IN#detailspecs
You said your running a Pentium Dual Core. Is that a Pentium EXxxx series chip, or do you mean a PentiumD...
The Gigabyte board is backwards compatable, it will run even Pentium 4's
That other board from Tiger however may not run a Pentium E series..
Discussion Starter #8
yeah my bad its in fact a Pentium E2180
the actual system is here
http://h10025.www1.hp.com/ewfrf/wc/d...roduct=3644689
is it backwards compatible w/ Pentium E2180
Yes, also I wouldn't recommend PCchips, they're a lil more hit or miss than ECS, and ECS is pretty bad.
Foxconn and Biostar make decent to good boards, gigabyte is highly regarded generally aswell.
Old school
The Pentium E2180 is a Core 2 Duo. It's the same type of CPU, but with some cache cut off. So yes it's guaranteed to work. That Gigabyte G31 would be fine.
Discussion Starter #11
Discussion Starter #12
1 - 12 of 12 Posts
