1 - 19 of 19 Posts
Alright, all my specifications are that I need and Antec 1200 case, a 22" monitor at least a 1920x1080 resolution, either a 4870x2 or a 295 video card and an i7 processor. I have never overclocked before, and I plan to do it here. I wasnt pretty low temps and I know how to build a computer, yes lol. Also try to keep it under 1750, 2000 tops.
I think their are a few but for a resolution of 1920x1200 you will need a 24" monitor minimum. If you already know what you want, what do you need us for?
Im not good with mobos and picking out reliable ram and such. Plus I need to make sure its an easily overclockable processor. I'll do my "homework" and such of course. Also I wanted to make sure I wasn't making a horrible call with what I posted.
This will give people something to work with and build off of, so that they know what you need. I know you want to overclock, but how do you plan to use the computer? (e.g., Video/Photo editing, Gaming, Business, Folding, etc.) Just to give people an idea of how you plan to use it.
CPU: i7 920 or 940 $290/$560
Heatsink/Fan:
MB:
RAM:
GPU:
PSU:
Case: Antec 1200 $155
Monitor:
edit: Also do you already have an OS or will you be buying that as well?
Heatsink/Fan:
MB:
RAM:
GPU:
PSU:
Monitor:
Im going to use 64 bit vista then repartition when windows 7 is stable some day and I game and video edit maybe a little photoshop too.
Windows 7 has a workable beta right now. I've got the 64-bit partitioned to play games and its pretty nice.
What kind of games?
What kind of games?
Lots of games, all the new games comign out adn such I also want my mobo to have two-three slots pci express x16 in case I need to add another gpu(s) down the line but as of now crysis, gta 4 and a few others, and editing HD video if that matters.
antec twelve hundred $154.99
http://www.newegg.com/Product/Produc...elve%20hundred
ASUS P6T $249.99
http://www.newegg.com/Product/Produc...82E16813131359
Core i7 920 combo with Sapphire Radeon HD 4870 X2 $288.99 + $414.99 - $25 combo
http://www.newegg.com/Product/ComboD...t=Combo.165221
G.SKILL 6GB (3 x 2GB) 1600 (PC3 12800) DDR3 $109.99
http://www.newegg.com/Product/Produc...82E16820231247
CORSAIR CMPSU-1000HX 1000W. Solid PSU that'll give you lots of room to expand $259.99
http://www.newegg.com/Product/Produc...corsair%201000
Western Digital Caviar Green WD10EADS 1TB 32MB Cache SATA 3.0Gb/s Hard Drive - OEM $104.99
http://www.newegg.com/Product/Produc...82E16822136317
SAMSUNG T220 Rose-Black 22" 2ms gorgeous monitor, I have the 24" version and couldn't be happier. $269.99
http://www.newegg.com/Product/Produc...82E16824001273
Total with rebates but not including shipping: $1768.92
You could skimp out on some stuff if you wanted to (like get an 850TX psu) or a cheaper monitor (I just love mine). Also you can probably find much better deals if you look for a while, I just grabbed the first thing I saw to put it in your price range.
edit: forgot hsf
XIGMATEK Dark Knight-S1283V
$39.99
or better yet get a TRUE or Noctua NH-U12P
ASUS P6T $249.99
That's a great build. And you're right about the 850TX - It should be more than enough to power that rig.
Discussion Starter · #14 ·
ASUS P6T $249.99
edit: forgot hsf
$39.99
Thanks a ton, this is a bunch of help, I'm probably going to buy this after just going over some things, and adding antoher 1tb hdd
ASUS P6T $249.99
edit: forgot hsf
$39.99
honestly a lower wattage psu is in order 1000w is kinda overkill
yeah get the 850TX
AND GET A SAMSUNG 24"! do not spend all that $ for a dual gpu card for 1680x1050 get a 24" for the extra $100 and take advantage of your GPU!
Reactions: Shift.
Originally Posted by sgdude
yeah get the 850TX
Agreed. Get an 850TX and use the money to buy a bigger, badder monitor.
yeah get the 850TX
Bingo. +1
1 - 19 of 19 Posts
