Originally Posted by mudd
first you need to read the intel stickies up at the top of the page about overclocking.
THEN you need to find out for yourself how high you can take each the CPU and the FSB individually, and them make them work in harmony with each other. I don't know much about the 915 procs, but 4 GHz seems pretty high on air. especially if you don't know what you're doing.
EDIT so i was a bit wrong, but got close.
http://www.xtremesystems.org/forums/...&highlight=915
um okay thanks,
anyways, im just fine with my knowledge on ocing, im wondering if somebody has some experience with it, see...i got it at 3.9 right now, just wondering if theres something im missing, maybe with voltages, im not too experienced with this particular processor, and i remember reading somewhere that the voltage shouldnt go past 1.30, but i dont remember
At the moment im having thoughts that it could be my power supply since i have some hungry components, and with an oc that high there just simply might not have enough power to keep the oc up, see i got it to 4ghz booted up into windows, but i get random restarts
got my vcore at 1.35 and even put a divider on my ram, so i know thats not the prob, and my temps are fine
I was just askin for some tips from someone whos experienced this prob, or knows more then i do about it,
am including a screenshot
