1 - 20 of 21 Posts
I unclamped those white things, but the fan doesn't come off, it's not screwed in from the bottom.<br><br><a href="http://imageshack.us" target="_blank"><img alt="" src="http://img183.imageshack.us/img183/8553/dscf1678bo3.jpg" style="border:0px solid;"></a><br><br><a href="http://imageshack.us" target="_blank"><img alt="" src="http://img206.imageshack.us/img206/7306/dscf1679yu5.jpg" style="border:0px solid;"></a>
hmmmmm..never seen one like that. interested in the outcome for future reference if I come across one in a customers pc. Do the release tabs fold all the way over in the opposite direction??who makes it??
Try using a blow dryer on it for a little bit till it warms up then twist off gently.
First, you want flip both of those white levers on the top that are keeping it secure. When you have done that you will notice that there are four hooks or black legs that you need to unhook on each corner which will then enable you to lift the heatsink/fan right off....Take your time and use common sense... its really easier than it looks.. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #5
okay. I am trying it. Hang on
Are you just trying to use the fan and discard the heatsink? Cause that needs both heatsink and fan in place for it to mount on right and cool cpu.. They are custom made so if you just want the fan then you'll have to get another heatsink/fan for your processor...
follow the sides down there you see it is clipped in just push down and pull outward the bottom clips
Discussion Starter #8
YAY!!! it worked! Thanks. Ok. Now another question.<br><br>
I have this Processor.<br><br>
I am writing what I can read, the letters are very warn out...<br><br>
Intel Pentium 4<br>
2.66 Ghz<br>
SL60A MALAY<br><br>
What type of RAM would I use for it? I need it badddd!! I'm dying here.
What is your motherboard? I can tell you everything from that... But I'm pretty sure you have socket 478, P4 2.66ghz with 512kb cache and 533mb FSB, you will probably need DDR ram....
Discussion Starter #10
<div>Originally Posted by <strong>guitar22891</strong></div>
<div style="font-style:italic;">What is your motherboard? I can tell you everything from that... But I'm pretty sure you have socket 478, P4 2.66ghz with 512kb cache and 533mb FSB, you will probably need DDR ram....</div>
</td>
</tr></table></div>
I have no clue, what motherboard. I don't have the papers for it.<br>
How do I tell?
model number is printed right on it...usually in big white letters right near the pci slots....<br>
If you still can't find it take a picture of you motherboard...
Discussion Starter #12
Okay near the fan it has this written:<br><br>
648FX-A REV:1.0<br>
15-H15-011002<br><br>
on the underside it says<br><br>
BLD PS-1 94V-0
Discussion Starter #14
okay.. how about this...<br><br>
ices-003 (that's written in small letters)<br><br>
There is nothing written in huge white letters.<br><br>
unless I am on crack... wait was that a yellow elephant that just ran by?
Ok got it here is you motherboard:<br><a href="http://www.motherboard.cz/mb/ecs/648FX-AV10.htm" target="_blank">http://www.motherboard.cz/mb/ecs/648FX-AV10.htm</a><br>
So I was right you are looking for DDR ram... DDR400 ram... Now I recommend atleast 1GB of ram but what is your budget... what are you willing to spend on the ram? Do you want high performance (overclocking) ram or just cheap ....<br><br><b><span style="text-decoration:underline;">Motheboard Specifications:</span></b><br>
Supports 400/533/800 MHz CPU FSB.<br>
AGP 8X<br>
USB 2.0<br>
Socket 478 for Intel Pentium 4 processors<br>
FSB 800/ 533/ 400MHz<br>
Support Hyper Threading Technology<br><br>
North Bridge: SiS648FX<br>
South Bridge: SiS963L<br><br>
3 x 184-pin DDR DIMM socket support up to 3GB ( DDR400 up to 2GB )<br>
Support DDR400/333/266 MHz 2.5V DDR SDRAM<br>
1 x AGP 8X/4X slot<br>
5 x PCI slots<br>
1 x CNR slot<br>
Support by SiS963L: 4 x Ultra DMA133/100/66 devices<br>
ATX Form Factor
Discussion Starter #16
<div style="font-style:italic;">Ok got it here is you motherboard:<br><a href="http://www.motherboard.cz/mb/ecs/648FX-AV10.htm" target="_blank">http://www.motherboard.cz/mb/ecs/648FX-AV10.htm</a><br>
So I was right you are looking for DDR ram... DDR400 ram... Now I recommend atleast 1GB of ram but what is your budget... what are you willing to spend on the ram? Do you want high performance (overclocking) ram or just cheap ....</div>
</td>
</tr></table></div>
I love you. <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
I need this as a secondary PC, for testing stuff, and backing up my files.
<div>Originally Posted by <strong>not l337</strong></div>
<div style="font-style:italic;">I love you. <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
I need this as a secondary PC, for testing stuff, and backing up my files.</div>
</td>
</tr></table></div>
So just some budget ram I suppose... I recommend this:<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820220045" target="_blank">http://www.newegg.com/Product/Produc...82E16820220045</a><br>
Its patriot, timmings are superb, and 1GB DDR400<br><br>
Also... these:<br><a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80082-19" target="_blank">http://www.zipzoomfly.com/jsp/Produc...tCode=80082-19</a><br>
or these will work<br><a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=83433-7" target="_blank">http://www.zipzoomfly.com/jsp/Produc...ctCode=83433-7</a><br>
but both out of stock...
Discussion Starter #18
okay WTH. How many different pin types are there?!?! I need 184 pin for this motherboard?
<div style="font-style:italic;">okay WTH. How many different pin types are there?!?! I need 184 pin for this motherboard?</div>
</td>
</tr></table></div>
There are whole bunch of different types of RAM that have a different number of pins... All you need to do really is concentrate on getting DDR ram (preferably DDR400) which has 184pins..
Discussion Starter #20
heh okay. I am going to ask a friend if he has any. I can't afford any of that right now, not newegg, not ebay, not anything. I probably need 256 ram for now... when I get money I will upgrade.
1 - 20 of 21 Posts
