Hey E-Peen you have a really nice rig, let me take a look at your cable man-
With side panel:
Without side panel:
I need your help, we must start this quest together. With your help I will defeat Medusa.
Work that needs to be done:
-My PSU isn't modular so I literally have dozens and dozens of these sleeved disgusting cables left over, and I have nowhere to hide them since I have what I would consider a small case.... or so I think.
-The USB 3.0 wire going over the GPU I believe I can solve by simply using a different back expansion slot so it won't have to stretch over the GPU making it look ugly. I will see later.
-The red and yellow wires going across the case to the back expansion slot is for my two cold cathodes. I cannot think of any other way to hide that.
-Turn HDD around.
-Figure out something as far as the cold cathodes go.
-Flip PSU over, and put case on a piece of plywood.
-I need to clean my side panel.
Accomplished:
EVERYTHING!
More pics and things needing to be done will be added soon.
Finished product (thus far):
I did my best. That cable going over the GPU was really annoying me and I decided to just leave it until I go to do a reseat of my H70.
Everything was solved with Duct Tape, basically. The entire back of my rig is Duct Taped cables. I did my best to clean up the cables near the PSU that were unused, I brought them through the bottom hole and up towards the top of the back end. I then used Duct Tape to tape them against the back side of the case. Even though the cables are still visible, it looks a lot better than it used to.
Only thing that went wrong during this process: When I turned the HDD around, it wouldn't lock in. So if I move my rig too much my computer will shut off. I'll solve this later.
With side panel:
Without side panel:
-Turn HDD around.
Accomplished:
EVERYTHING!
