I need help My computer is only seeing one cpu
696 Views 17 Replies 7 Participants Last post by  Neko_X
I have 2 intel xeon and my computer only seeing one of them but if i go to device management i see all 4
1 - 18 of 18 Posts
Originally Posted by GlockZoR IV;13037716
is your ram installed over both CPU's?
yes?
Originally Posted by derickwm;13037729
You have two 5150's but only 4GB of ram and a gts450? FOR REALS!?
lmao are u willing to gift 4gb xD u know how much my ram costs lol
GlockZoR IV do u have team viewer u can tv me to look
Os?
Do you have the most recent bios for your motherboard?
Do you have the most recent drivers installed for your motherboard?
Your computer profile doesn't state which mobo you have.
Also download and check your mobo manual, on 3 of my board I can turn cores off in bios but its specific to each board.
well its an hp workstation xw6400
Can you please be a bit more informative? What do you mean when you say "my computer only seeing one of them but if i go to device management i see all 4"? That doesn't make any sense. Do you mean the BIOS only sees one CPU? Or if you right-click/properties on My Computer, it only sees one CPU? What? If device manager sees all 4 cores, then what's the problem exactly?
If you installed your OS on a dual-core cpu then upgraded, you will have to reinstall the OS for Windows to know it needs to install a different HAL (Hardware Abstraction Layer). If it was installed on a dual-core, it won't know how to address the quad.
Wow, I had no idea it worked like that--very interesting. There's no way for a simple "update" in cases like that?
He says that hardware manager shows all 4 cores (from what I can interpret).
I wonder how many threads taskmanager shows. OP, open up taskmanager and look at how many CPUs it shows in the Performance tab. Are all active if you load up something like a benchmark or app that can use all of them? If it's showing 4 there, and 4 CPU's in device manager, then I wouldn't think there's a problem.
its shows 2 cores and i did'nt just install the second cpu it been there my windows cpu and ram score went down too...
i had it on windows 7 home premium x64 and i now upgraded using a ultimate key i now see 4 cores 2 cpus
it was seeing 2 for a while then it stopped
1 - 18 of 18 Posts
