Originally Posted by Flattit4 hai i need help on my overcloking my memory. and i don't anything about memory? i got 512 pc2100 and 512 pc 2700 |
Originally Posted by YiffyGriffy He's got a 1.8 Northwood and a 533FSB though, PC3200 would be plenty, but if you've got that processor overclocked from 1.8 to 2.4 like that readout says you've already overclocked the memory |
Originally Posted by Flattit4 so my memory is already oc is it? is that my memory suppose to be more that 1024 is it? |
Originally Posted by Flattit4 mmmm i get it that alot guys |
Originally Posted by Flattit4 oke, how much do u thing is gone coast? and 1 more question with my system is that possible to cloking more? because i planing to give away my cpu to my sister and get a new 1 |
Originally Posted by mfillpot The cost for the PC4000 is not much greater then PC3200, with the higher RAM you will be able to obtain a 1:1 ratio which will aloow for greater overclocking, and also with the RAM rated higher than you system specifies you will be able to put a higher voltage into it without the worry of massivley overheating your ram. |
Originally Posted by Flattit4 can u thell me 512mb ddr333 what that stand for??? i mean the ddr333? and can u give me advice should i use pc2700 only or just use pc2100 and pc2700 since i'm still broke ![]() thanks |
Originally Posted by Flattit4 that mean that i can cloking more is it? |
Originally Posted by archer_456 Since your RAM is running at it's rated speed you should be able to OC it more and keep a 1:1 ratio. If you are able to Increase the FSB you shouldn't have a problem with your memory holding you back. I can't tell you how far your memory will OC, it's something you will have to find out. |
Originally Posted by Flattit4 but how? is that the same way that i'm cloking my cpu and how do i keep the rasio 1:1 sorry i'm not realy know that much about memory |
Originally Posted by archer_456 Continue to OC the same you have been doing. As you increase the FSB the memory will also increase at the same rate. once you hit a wall and start getting reboots or any other kind of problems then you need to back it down a little. This is the point where you start looking at voltages and such. Remember if you get to a point where it won't boot at all, just clear CMOS and it will reset everything back to default. Is there anyway you can get a CPU-Z screen shot of your CPU and Memory tabs? |
Originally Posted by Flattit4 if u say that cloking the same i have done it and the high i can get is 2.4 wich is now and i have 400w and i change the v to 1.6 is that all i can do or i missing something thanks lo |
Originally Posted by mfillpot First off thank you Archer for adding what I forgot about the reason for the 333 being twice the bus rate. As for your system I beleive that the voltage you are using is too much(as per posts I have read), but want someone to verify that for me. again like I said if you remove the PC2100 then the default transmission rate for the remaining PC2700 will be 166Mhz and by running the same voltages you are you will be able to achieve a higher transfer rate than the default 166Mhz for the PC2700. |
