1 - 4 of 4 Posts
well im putting my computer together and i have the scythe infinity cpu cooler. i went to plug the fan into the motherboard (p5w64) and the fan has a 3 pin connector on it but the motherboard has a 4 pin male on it . is there any way to convert my 3 pin to a four pin???
You should be able to plug it into just 3 of the 4 pins. <br />
<br />
There should be a "[" shaped thing around the pins and the plug should just slide in happily.
me so stupid, you so smart.... i cant believe i didnt see that!!<img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /> well i appreciate the helP!!!
No problem =D
1 - 4 of 4 Posts
