1 - 16 of 16 Posts
SO when I oc my CPU to 2.58GHz...it drops down by it self to <img src="/images/smilies/gunner2.gif" border="0" alt="" title="Gunner2" class="inlineimg" /> 2.529-2.533GHz with out me doing anything! So when I go back to the Bios to overclock it again, I see that the speed of the cpu is 2.58GHz...so then why does the cpu speed fall back down when windows starts? Is it that there is a lack of power to the CPU? Should I up the Power abit?<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
How you OC in bios or windows?
<tr>
<div>
Originally Posted by <strong>alexisd</strong>
</div>
<div style="font-style:italic">How you OC in bios or windows?</div>
</td>
</tr>
</table>
</div>In the Bios, you can up the speed by 1MHz at a time...
I go 3 at a time all the way until I hit 2.6 after I go 1 at a time.You have anything else in auto?You have the feature of overvolt in that mobo?Mine have overvolt and I enable to have stability.Watch temp's if you do this.
Discussion Starter #5
<tr>
<div>
</div>
<div style="font-style:italic">I go 3 at a time all the way until I hit 2.6 after I go 1 at a time.You have anything else in auto?You have the feature of overvolt in that mobo?Mine have overvolt and I enable to have stability.Watch temp's if you do this.</div>
</td>
</tr>
</table>
</div>So you think that if I up the volts...that should fix my problem? Will cpu temp. be affected by this?
Yes temp's are a problem if you go or pass close to the 50c to 55c.What's your temp's now?And I can think reseat the cpu again and use good termal grease.And volt's can help too.You intalled the cpu by yourself?
Ok so you've overclocked it, when you play games, have you checked to see whats it clocked at? I may be wrong, but maybe your cpu is throttling.
Discussion Starter #8
<tr>
<div>
</div>
<div style="font-style:italic">Yes temp's are a problem if you go or pass close to the 50c to 55c.What's your temp's now?And I can think reseat the cpu again and use good termal grease.And volt's can help too.You intalled the cpu by yourself?</div>
</td>
</tr>
</table>
</div>yes...I built this bad boy(lol). My temps are posted in my profile.
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>selectodude</strong>
</div>
<div style="font-style:italic">It's either throttling, or you have Cool 'n Quiet on.</div>
</td>
</tr>
</table>
</div>I have Cool'n Quiet on...should I turn that off?
I'd say its throttling though I havent seen your temps, you could disable on some mobos, but I dont suggest it.
Discussion Starter #12
<tr>
<div>
Originally Posted by <strong>RickJS</strong>
</div>
<div style="font-style:italic">I'd say its throttling though I havent seen your temps, you could disable on some mobos, but I dont suggest it.</div>
</td>
</tr>
</table>
</div>My temps are posted in my profile.
Yeah. Turn it off.<br />
<br />
Looks like you got a lot of bad advice in this thread. Sorry <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />.
I think we all try to help.But I hope when you disable cool 'n Quiet your problem is solve Good luck.
Discussion Starter #16
thanks guys... Everything worked!
1 - 16 of 16 Posts
