Hey Guys,
So I am trying to sleeve my Seasonic 1000w Platinum.....
Lets just say its not going well at all.
I have tried everything to try and get the pins out but nothing works.
I don't even here a click, I wiggle the wires and twist and turn and push in and out to try and prep them to remove them from the connector but nothing helps.
I have searched and searched (youtube videos, the threads here)
I have tried paper clips, staples, even MDPC's removal tool.
I place the prongs between the pin and plastic housing and make sure its there and not in the pin itself.
Then I start to push in the tool, or what have you, while pushing in the wire as well but I hear no clicks.
Someone please give me a heads up if you see anything wrong here from my description.
I can't imagine that its that difficult to remove the pins from the connector, I know they said its hard but didn't know it would be this difficult.
