the temp was high on CPU so i changed the orignal fan with a 4000RPM and also i add 3 more fans 2 pull and one inside 15cm fan (push) over the motherboard
before when i check the temp on BIOS its 50-55. with windows starts i guess its rising up and sometime it restarts coz of high temp.
with the fans it lowers the temp maybe 5c or 10c max
and also sometimes when i use lot of programs the system restarts coz of the high temp.
so whats the problem, is it the room temp some times its hot or something with the fans?
can u help me guys?
can u help me guys?
