1 - 20 of 31 Posts
HI guys,
The other day i was using my 8800GT on my pc, and it just blow up, "DEAD". Now im doing some research to get a new one that i can afford, i was thinking on the 260GTX or 280GTX which are around 150 with Mail Rebate over Newegg.com,
If this is a Great card, which brand do you guys recommend ? I was using the EVGA over my 8800gt which is a really good one for my understanding...
Please Open To suggestion Under 150 Dollar. Thanks.
You can find GTX260's for around $120 (I saw an XFX card with the second lifetime warranty for ... $120 I think?) and 275's for about $150.
There's probably also some good ATI cards, but I haven't been keeping up on who's edging out who in the benchmarks.
Yup looking at the FS section of OCN is a smart move but if you want new..
Are you looking to stay with NV? If not here is a good card for the price.
After rebates works out to be $113.
If staying with NV here is a good card.
Your best bet in your price range is a GTX2xx card. They beat out the competition and will give you better overall performance up to 1920x1080.
If you can find a GTX280 or 285 for under 150$, that's what you should get. If not, try to get a 275 as it will perform better than the 260 at higher resolutions.
GTX 460 should cost $170.00 in a week or 2.
Discussion Starter #11
Ty guys, you are awesome, im really glad, i think i will go for the 260-280 GTX, i will let you know which one i will get.
Btw, i do have a Zalman VF1000 Fan, does it will fit or should i sell it ?
Originally Posted by Xtrl View Post
The 280 GTX BFG 1GB is a good brand? was looking into it and it beat 260gtx evga
Great card if you don't need warranty. BFG no longer takes RMAs.
Discussion Starter #14
GTX 260 1.8 GB ? Is that better than the normal EVGA 260gtx ? Im reading is a Custom or OEM from HP, but cant see any forums with that review. Can someone enlighten me please.
I don't know if they made a GTX260 with that much VRAM. But if they did, it'd be better for larger resolutions. 1GB and over is good for 19xx x 10xx and larger. Anything less is ideal for 16xx x 10/12xx and below.
Discussion Starter #16
well, im using a Samsung Monitor 24 inch 1920 * 1200, So i think could be wotrh the shoot, right?
Discussion Starter #17
and yes, they made it, for custom riq, like HP or something... 1.8 gb with no brand, or stickers.
Sure - if it's a good price grab it. But if you can, you'll really suffice better at that resolution with a card that has a little bit more horsepower behind it. A GTX280/285 would really fit your resolution better than a GTX260.
Discussion Starter #19
Im looking for something that covers my need but dont want spend a lot of money, so i bet 260 gtx is on my bugde now... i will keep an eye over 280 gtx too.
1 - 20 of 31 Posts
