1 - 4 of 4 Posts
Hello,
On Sunday, I was trying to replace my CPU cooler.
I accidentally damaged one of the capacitors on the motherboard, and the computer worked for two days and then suddenly stopped working.
Is there a chance that the CPU is damaged?
My CPU is 4930K, and I don't know if I should buy a new motherboard.
Thank you in advance.
Rig Advisor
Picture of said damage?
Intel CPUs are hard to kill. Check for bent pins. Depending on where the capacitor was, it might not have been doing much.
Invalid Media
...yeah, as suggested above, a pic would be nice. Also, did you keep the capacitor (and/or is it still on there)? That would be helpful re. replacing it. Finally, if you inadvertently bent pins in the socket, not all is lost, depending on how badly they were damaged. I recently 'brought back' an Asus Rampage V Extr X99 that had several bent pins after a few LN2 sessions and was running on only one of four memory channels (more on that > here ).
Put differently, you may be able to get your system back w/o major expense.
1 - 4 of 4 Posts
