My problem is I was installing my psu, which is a thermltake 875watt toughpower (80 plus bronze) for my 6950. Now, previously I placed strain on my sata cables, which caused a "static" flamely short out now my hard drives and ssd don't detect. But my motherboard,cpu,ram and optical drive detects. Its happened twice now. Though when I had my old antec 550 watt true power Power supply, with my old gts 450 no problems occoured. Once I placed my 6950 and 875 watt psu in the existing system it killed my HDD'S and ssd. I then bought another mobo, ssd and hdds and killed them again. I using the same PSU.
Stupid of me I know. I think my PSU is the reason my SATA controller dies every time. If someone could tell me another reason that'll be nice.
Note: nothing is overclocked in this system apart from my graphics card which is factory over clocked. Also my 875watt psu used to work perfect with my i5 750 (quad core) 1156 cpu.
Specs:
990FXA-UD3
AMD 8350 4.0 GHz
1GB gddr5 6950 gigabyte (OC version)
8GB kingston ram (1333mhz)
Recently placed in Thermaltake 875watt bronze certified. Which I think is the problem.
Specs:
990FXA-UD3
AMD 8350 4.0 GHz
