1 - 9 of 9 Posts
Originally Posted by freddy-b View Post
i iam doing a 4ghz OC on my Q9550 and here are my settings
Vcore: 1.32v
VTT: 1.30
PLL: 1.54
my temps reach 80c with prime...
what do i do..?
Try reseating your HSF. If that doesn't work, upgrade your Fan/Fans on your HSF.
That is WAAAAAAY high for a Q9550 @ 4GHz and only 1.32vcore! I could see that MAYBE with Intel Burn Test, but not Prime95.
Buy some watercooling
But really, urm either get a better cooler or faster RPM fan. If you can set up a push/pull system on that HSF and see if that improves your temps
is it true that from 3.90Ghz to 4.0ghz u have to Bump the Vcore much higher...?
Depends on the chip really. I'd try re-seating your HS because those temps seem high for the voltage.
Usually Intel chips have a very uneven IHS so I would try if your cooler gets even warm while in full load. If it doesnt, your contact is bad. Reseat cooler and/or lap your CPU. Lapping Intel chips really pays off if you have a uneven IHS. My friend lapped his umm... some E43XX and got about 10C drop at load
1 - 9 of 9 Posts
