Well, here is the situation.
C2D rig from sig:
I was messing around with some things inside the case and then went to turn the computer on. All fans begin to run but nothing displays and it does not boot into OS.
So then i decided to try to troubleshoot the problem.
1) Swapped out video card with one that i tested (8500)
2) Tested different memory modules
3) Reseated all power and data connections
After all that I switched the jumper to maintenance, bios loads. I then skimmed through the options, everything looked right, even memory was still reading at 4 Gb.
Switched jumper back to normal, fans run without video display and no boot again.
Removed the battery and tried again after 10 minutes, same thing.
Any ideas on what is wrong with my PC?
Don't know if it was worth mentioning, PC was in sleep mode and i accidentally unplugged without shutting down the OS, before i was messing around inside it.
Edit: To clarify, it doesn't even post without jumpers in maintenance.
C2D rig from sig:
