1 - 9 of 9 Posts
what's are the mods to make oblivion look the best it could. i don't care if i end up playing at 10fps, i just want to know what mods would make oblivion look amazing.
Qarls Texture pack.
i think Darknut has done some work on oblivion im not too sure tho (he made some great morrowind texture packs) and then theres immersive interiors bananna spilts better cities. I cant really think of any others right now. See how that goes for you.
Originally Posted by Dwalin Co
Qarls Texture pack.
Qarls fo sho. Still won't push your card down past 50FPS most likely, but damn does it make oblivion pretty...
When I modded mine up it looked amazing and the frame rate was spot up but it used to freeze for a split second quite often which was a PITA. If you have an SSD try putting it on that.
Qarls + Open Cities + Everything Visisble when distant + living waters + 32xAA
*EDIT* Also, Immersive homes and Illuminations within.
1 - 9 of 9 Posts
