If I use in df, is it OK?Originally Posted by xd_1771
Actually, it has. There has been one recorded failure on this board in January, on a lower voltage (<1.4V) Phenom II x4 overclock. A weak 4+1 phase known for failure should be avoided for use with 125W Phenom II x6. Cooling doesn't necessarily prevent failure in all cases, VRM capacity may be an issue. I think the low demand might explain the lack of extra failure incidents to be found.
Not in my country
the whole thuban series is now deactivated..
