1 - 11 of 11 Posts
My fan has just fail,and i want to buy a good fan and i don't have the money right now is it safe to play games with the cpu on passive cooling from the hyper 212+ radiator ?
After 10 min of prime 95 the temps reached 81 degrees
Well, those chips wont run that hot when you game normally, but it is above the comfort zone definitely, so I would get a fan ASAP. You can help the temps by providing better cable management in your case and better airflow towards the 212 plus wherever possible.
I don't know how hot I3 540s get but just keep an eye out on the temperatures. Don't do anything intensive until you get a fan.
edit: Actually, if anything...if you have a 120mm case fan, put it on your heatsink instead of your case.
Better safe than sorry on this one, get a fan, or cable tie a temporary case fan onto the heat sink for the time being
If your case has any kind of fan just stick one on, I mean anything because even a little airflow should be enough for such a low power chip.
I get better temps than that running LinX at 4.4GHz and my chip is on 1.5V.
If you don't have anything, try underclocking to 2.8GHz or something until you get a fan, that or just plow ahead on the stock settings because that's what I'd do if I'm being honest.
Edit: Just realised that that's after prime, it's probably fine if it stays below 70 for everyday use which I believe it should.
1 - 11 of 11 Posts
