Hey there, I could use a hand with overclocking this CPU. Using Gigabyte Z170-HD3P motherboard and i3-6100.
I have followed all the steps from here http://overclocking.guide/gigabyte-z170-non-k-overclocking-guide/
When I save the values in BIOS, the PC resets to set the voltages and clocks. After the reset the monitor stays in sleep mode and after few seconds the PC reboots itself again and takes me back to BIOS saying my configuration failed to boot and resets the values back to stock. I haven't found anything regarding this anywhere, looks like everyone can OC without any problems at all, but not me. I've tried using F5g, F5 and F5i BIOSes, each ended with the same thing. Same thing happens even if I raise the BCLK just to 101. 105 BCLK with RAM set to 2800MHz boots. 110 BCLK with RAM set to about 2600MHz doesn't boot. 122 BCLK with RAM set to about 2600MHz doesn't boot.
Any help would be appreciated!
