1 - 5 of 5 Posts
Hey guys! I have a couple issues with my setup right now.
I am running
core i5-2300 Stock cooler, properly re-applied thermal compound
4g ram
msi H61MU-E35 motherboard
Nvidia 8800 GTS 320mb graphics card
stock 500W power supply
two rear fans, one side fan
windows 64 bit
First of all, when I play games with graphical intensity (starcraft, crysis), my computer simply reboots. No blue screen no nothing. I logged my processor temps and they nominal during these situations. This occurs during situations of graphical intensity,
HOWEVER- the same graphics card was able to handle even higher loads on my previous machine.
Secondly, I have done a few Prime95 torture tests on the processor. And it reaches 75+ degrees celcius after 3 cycles of Prime95. Now I have read about other benchmarked 2300s with stock coolers going nowhere near this in that amount of time. I am just wondering if there is something wrong with my processor.
Anyways, thank you for reading and perhaps I won't have to resort to reformatting.
It came installed in the Apevia XQboii case, I dug up these specs.
ATX 500W power supply
-1*120mm built-in fan
-Wire management:all wires are sleeved
-Standard size:150 x 140 x 85mm (W x L x H)
Power Supply Spec.
AC INPUT 115V/230V - 60/50Hz
DC OUTPUT +3.3V +5V +12V1 +12V2 -12V -5V +5VSB
Watts 25A 30A 16A 18A 0.6A 0.6A 2.6A
500W Max
Combined
Power Supply Connectors
•1 x 24pin Main Power (20 + 4 pin)
•1 x 12V (P4)
•6 x Peripheral
•2 x Floppy
•2 x SATA
•1 x PCI Express
Power Supply Spec.
500W Max
Combined
•1 x 12V (P4)
•6 x Peripheral
•2 x Floppy
•2 x SATA
•1 x PCI Express
It might be the PSU. The wattage is fine but because of the brand it's not reliable at all.
Thanks, I will try out a different PSU, a little while ago we had a series of power outages at my house, the computer was connected to a surge protector, but it may have had an effect.
1 - 5 of 5 Posts
