Do an Intel Burn Test on Very High, it does 10 pass. If you pass that without hard freeze or BSOD, usually a good indication of stability. Then I would just do another Intel Burn test after that, instead select custom and use about 80-90% memory usage. If you pass that too, then you should definitely be stable.
