Seems you have just gotta play with the offset until you get it were you want.The major thing to note about this board is that there is no way to directly set the vcore. Vcore appears to be determined from a combination of your chips native VID, the value and sign of the CPU Offset Voltage, and the Additional Turbo Voltage (ATV) setting under the CPU Power Management Menu.
