Alright, so at this point I'm about ready to puke.
I'm really getting sick and tired of trying to overclock this thing and spending weeks trying to get it stable.
First off lets start with my goals.
4.7 GHz
any voltage under 1.5
12 hour Prime95 blend stable using 90% RAM (sandy stable club)
temps under 85* MAX (80 preferably)
Alright next, screenshots. Here is my CURRENT 5 hour stable Prime95 blend settings.
I've ran these settings a few times at around 5 hours I get BSOD 124. I've ran 15+ hours on battlefield 3 with these settings.
Ok so, I've tried MANY things to get this stable and I'm completely unsuccessful apparently. I've tried upping the voltage, lowering the voltage, changing multiplier and upping/lowering voltage, lowering PLL voltage, upping VTT voltage, changing RAM settings, enabling/disabling random things like c3/c6/thermal throttling/PLL overvoltage/c1e ect, ect ,ect... I've basically tried it all and some how I can't get this CPU to run longer then 5 hours on Prime95.
I REALLY NEED HELP!
I don't know why I cant get this stable. I've pumping more then enough voltage for any multiplier I set it to. 1.45 volts for 4.7 GHz I've never seen and I understand all chips are different but there is no way my chip requires more voltage. It must be something else!
I'm lost for words lately and I feel like just giving up. All I want is 4.7 GHz stable. I don't even care for 4.8, 4.9, 5.0 GHz. I just want stability at 4.7.
Please enlighten me with what I could possibly do to make this stable. PLEASE!
Side question: I included my fan screenshot there because I've had a question I needed answered for a while. Is it possible for me to raise those speeds? The side fan of mine seems a bit slow, not sure, but I'd love for them to go faster. The settings they are on is maxed I can go. Full on and level 5. Anyone know?
BTW: I've read almost every post, sandy stable club, all these posts that others make, guides, ect, ect and they don't help. I've tried so much.
System is in sig.
4.7 GHz
I REALLY NEED HELP!
System is in sig.
