1 - 20 of 88 Posts
We won't know for sure until someone tries.. I haven't seen anyone try yet. You will have to use the same vm ware setup that the guys with amd 6 cores use to trick the client into thinking you have 8 cores... I've never done this myself..
You will need this guide:
http://www.overclock.net/folding-hom...igadv-amd.html
That should have all the info you need to set it up. Sorry I can't help much beyond that. Please do let us all know if it works out, and head on over to the sandy bridge database in my sig and pass along your findings!
Yeah, you'd be leaving yourself very little/no room for errors. I think it'd be best just sticking to SMP too.
Originally Posted by this n00b again
hmm all i can say is i've been doing smp for the past few days, and at 4500 MHz im getting around 1100 ppd.
Then no, not going to happen.
If you start getting at least 15k PPD on SMP then you can try bigadv with the linux trick. I believe you need around 4.8ghz to get that much though so good luck.
Discussion Starter · #9 ·
lols my mistake. i meant 11,000.
i forgot a zero
which project? if it's doing 11k on P6701 then i think it can bigadv
cus my 1090t gets 9-10k on p6701 and it runs bigadv fine
i forgot a zero
I knew what you meant, but still need at least 15k.
Koven has a point if it is a 6701/6702 then that is fine, but wait for other units and check what you get.
Discussion Starter · #12 ·
hmm looks like the ppd has adjusted it self down since the last time i looked at it.
and here is the clock:
Originally Posted by this n00b again;12027349
well i put the -bigadv flag on.
it's done more than 10 WU's but i just remembered.
it's pulling 15k ppd right now on smp.
lets see if it works... hmm how can i tell?
Originally Posted by KillerBeaz;12027378
you get a -bigadv unit
It isn't that easy.
You need to follow this guide.
you need to run it in linux/ubuntu to "fake" 8 cores in order to receive a -bigadv unit
follow that guide step by step, it's straight forward and works great
1 - 20 of 88 Posts
