i just finished building my new computer adn want to oc
i test out jut changing the multiplier to 45, everything was auto.
I know thats bad so i tried to look up so average voltages and such and got 1.4v @ 4.5ghz
my temps are crazy high i think
40 idle and 80 on load....
I'm using a 212+ with push/pull
my old e8400 wouldn't go higher then 55C i think on load. and was below 39 on idle
computer specs:
gigabyte z68x-ud3h-b3
i5 2500k
gskill ripjaw 1600 8gb 9-9-9-24 ddr3
212 plus cooler
cm 690 case
radeon 6850
windows 7 64 bit
I would like to Oc the ram too
i'm not sure what voltage other things should be set at also
mostly everything is on auto right now
computer specs:
i5 2500k
212 plus cooler
cm 690 case
radeon 6850
windows 7 64 bit
