basically I've set my CPU to 42x multi and core v to 1.265v (it won't stay stable at anything less..bad OC chip I guess).
When I'm stressing under Prime95 blend now and again the multi fluctuates between 39 and 42 like it will stay at 39-40 for a couple of minutes then back up to 41-42 for a while and so on and so forth, is this normal?
just as I type this one core failed after about 2 hours stressing, obviously even more v core is needed *sigh* but the multi dropping like that..is that a sign of insufficient voltage or just normal as the tests go through?
temps never gone above 65 deg load btw
