This was my second gaming build and I built with the intention to OC this time. I spent a couple of days reading and trying to learn what I can before trying.I found and followed the very well put together guide from here ( Complete Overclocking Guide: Sandy Bridge & Ivy Bridge | *ASRock Edition)
http://www.overclock.net/t/1198504/complete-overclocking-guide-sandy-bridge-ivy-bridge-asrock-edition
My build is :
-Core i5 3570K
-Vengeance Series 16GB(2x8gb) DDR3-1866 (PC3-15000)
-NVIDIA GeForce GTX 660 Ti Superclocked+ 3072MB PCIe 3.0 x16 Video Card\
-Caviar Black 1TB 7,200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
-Hydro Series H80i Extreme Performance Liquid CPU Cooler
-Z77 Extreme4 LGA 1155 Z77 ATX Intel Motherboard
-COOLER MASTER Real Power Pro RS-650-ACAA-A1 650W ATX Form Factor 12V V2.3 / SSI Standard EPS 12V V2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply (from my last PC but still runs great,
I hope )
Like the guide said, I set the Offset to +0.005v and set the Turbo Boost to +0.004v. I was able to pass the test with a multiplier of 45 but 46 wouldnt boot up. I went on to the next part and put the multiplier to 46 and increased the turbo by one spot ( I believe to +0.008v). The BSOD i would get was mainly to add Vcore. I increased the turbo up about 4-5 different times which I think I stopped at +0.024V turbo. Would I keep adding the turbo or also up the offset? Whiled trying to find the right voltage, I also received the BSOD "0xD1" 0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage. After the "=" is the guides answer/solution. My Ram voltage was at 1.5v which I think is where it should be from a little research?
The only reason I am not content with the 4.5GHz that seems like it would be very easy to keep stable is because I feel like I can easily go higher and I am just not fully understanding where I should make changes after 4.5. My max temp of the 4 cores during the prime95 test was about 67-68C. Since the Max is 105C and I know I dont want to be anywhere too close, I wanted to see if I could get closer to 75-80C with a better OC.
I also noticed in the BIOS that the Ram I got was set to 1333 which I bought 1866. I changed this too and added the right timing.
If there is any information that I left out and someone may need to help me out, just let me know and I will provide it ASAP. This is my first OC so sorry if I have any misunderstandings here.
My build is :
-Core i5 3570K
