Hi all,
Thought I would post this as ive been researching and troubleshooting it for some time yet still have no resolution.
I'm getting cpu usage sitting between 90-100% whilst gaming on any games. This then causes lag spikes making it not too nice or smooth to play. Black ops 3 / far cry 4 / gta v. Even older games such as black ops 2 the cpu usage is sitting in the 60-100%. The problem seems to have occurred since I went 2560x1440 @ 144hz, but also around the same date their was a windows 10 update. I did remove the update but made no difference. I'm running windows 10 64bt. I have a good feeling it may be a windows 10 issue but im not too sure.
Set up is:
i5 4690k
980 Strix sli
z97 pro
16gb vengenge 2133
os installed on a 840 pro
games installed on a new 850 pro (also tried them on different ssd and hdd)
ax750
h100i gtx
Originally I had the cpu oc'd to 4.4ghz, stable, for 9 months with no issues, I have since tried it at stock settings, yet makes absolutely no difference to the cpu usage. I have refreshed windows 10, started again with all drivers but made no difference. I have reseated the cooler with fresh TIM after reading somewhere that solved a similar problem but did not fix it for me. CPU temps dont go above 60c.
GPU sli usage is a little bit spikey due to this, between 90-100%, I would expect the gpus to be sitting at 95-100 most of the time with AAA titles at 2560x1440. I have tried removing AA, reducing gfx settings in game, SLI disabled. None of these make any difference. Task manager and MSI afterburner show the same usage spikes. The games .exe in task manager showing 95- 100% when in game, so I dont think it is other applications running in the background. I understand games are becomming more cpu demanding but this shouldnt be happening.
I would love some help with this as Ive run out of ideas.
Thanks in advance!
Set up is:
i5 4690k
980 Strix sli
z97 pro
16gb vengenge 2133
ax750
h100i gtx
Thanks in advance!
