I am going to get a P55 motherboard and new RAM but as for the CPU, I'm undecided. I keep asking myself if it is really worth it to get the 860. My question is, is there more to the 860 than a higher clock speed. If yes, is it worth another $80. Also, overclocking. I know the 860 can often hit 4.0+GHz and since I have very efficent watercooling, I'm hoping for higher. Will I be able to go that high with a 750?
I would greatly appreciate some input as I am considering ordering today or tomorrow. And for you Intel guys, you finally won the support of a guy that has been AMD the past 5+ years. Also, I guess I'll have to get someone else to head the Phenomist club as my Phenom is going away soon!
EDIT:
Should I just spring for the LGA1366? I don't plan on spending more than $500 on CPU+MOBO now but I'd hate to regret buying LGA1156 on down the road. And could someone recommend a board that overclocks really well? And SLI/Crossfire is a must, yet another reason I'm going Intel, so I can go with ATI or NVIDIA and still be able to go with a multi-GPU solution without buying a new board.
