1 - 4 of 4 Posts
Hey guys.
I am wondering how far I could go with the i5-750 overclocking with a 80 degrees max @ full load.
I don't really know too much about overclocking exept the basics I guess.
This is my setup:
Antec 902
MSI Big Bang Trinergy P55 Motherboard
Intel Core i5-750 2.66GHz
Kingston HyperX 2GB DDR3 1600MHz ram
XFX Radeon HD 5770 'XXX' Edition
Corsair H70 Liquid Cooling.
I am having the 'Big Boy' fan (200mm) at the top obv.
2x 120 mm fans at the front.
1x 120 mm fan at the sidepanel
1x 120 mm fan at the very centre in the case (by the HDD room)
The radiator for the H70 is by the backpanel with its 2 fans.
I am using the push/pull system with the H70.
Would this be enough cooling to reach 4GHz stable with not too high temps?
Hoping to get this stable at a maximum of 80 degrees at load.
semi-legit
Should be just fine
Not sure what kind of ambient temps you're dealing with, but you shouldn't have a problem going over 4GHz with some good tweaking and a decent VID
Discussion Starter #4
Cause I am feeling uncomfortable with it. I haven't got too much experience with it
I guess I should watch a YouTube onscreen tutorial or something.
1 - 4 of 4 Posts
