5
Thank you for your replies.
Originally Posted by nathris
Its because the DRAM frequency still runs on straps.
Straps? Lost you there.
I just got mine today, but from what I can see you're either going to be running at 2:8 or 2:10.
FSB : DRAM correct? if (FSB > DRAM) Ram is bottleneck, if (DRAM > FSB), RAM is bottleneck. The optimum ratio is 1:1 i suppose?
Your best bet would be to run it at 2:8, which would give you DDR3-1440. Or you could try running at 200x18, which would give you DDR3-1600 at 2:10.
Will try that.
Originally Posted by Amdkillsintel
The QPI has to be a least twice your ram speed.
Does it have to be 2x of the 800Mhz or the DDR1600? IE for DDR1600 u need 3200Mhz QPI or for 800Mhz you need 1600Mhz QPI?
QPI: 2884.7Mhz
DRAM: 801.3Mhz
NB Freq: 2564.3Mhz
Bus: 160.3Mhz
off-topic questions:
Why does my dual channel memory show up as single in CPU-Z? (I am checking my memory config now)
Why does my core voltage no longer show up in CPU-Z?
Update:
Core: 3604.4MHz (180.2x20)
QPI: 3243.9MHz
DRAM: 720.9MHz
NB: 2883.5MHz
FSB : DRAM: 2:8
After Small FFTs 10 minutes (8k passed) Temps ~51-54*C
I am looking to push this overclock further, I cannot get it to post from ~3.8-4.1GHz with these settings, do I have to change voltages?
