i5 under water
953 Views 12 Replies 5 Participants Last post by  iquark
Hey all, I'm planning my upgrade, and I need to know what those of you with an i5 under water are getting OC wise.
Any info is much appreciated, but the best would be your OC settings (including voltages) and your temps!
Thanks in advance.
1 - 13 of 13 Posts
That's a good question. I'm at 4.0ghz on air stable pretty easy. I have been to 4.6ghz and even 4.7 on air for just benchmarking though(not stable). Not sure what it will do with water.
If you remember, what vcore were you around for 4.5ish?
I had like 1.36 I think. But that was no where near stable. It was enough to run 3d mark and super pi and stuff.
I've ran up to around 1.55v through my i5 and it hasn't passed 55c, I only run 3.4ghz at 1.2v 24/7 and it rarely passes 40c. My room is usualy pretty cold though..
I run mine at 4.3ghz and needs 1.41v to be stable. It folds pretty much 24/7 and the hottest core reaches 60°c. Stressing with LinX gets the temps up to around 75°c. I'm too lazy to try and re-seat the block to see if it helps.
What clock did you boot into Windows at with 1.55V? This is good news to me, as I would be very happy to sit at around 4.2 or so if possible with my loop.
This is also very good news, I'm pretty sure my GTZ is a bit more efficient than your XT. EDIT: My mistake I was confusing XT and GT again...
Assuming the i5 chip I get is solid, I should be able to reach my goal of 4.2 with reasonable temps.
Thanks for all the input so far. If anyone else has an i5 with a loop, and would like to chime in, please do so! I like to gather as much info as possible prior to any big purchases, and a platform upgrade is definitely one of those.
iquark, unfortunately the Apogee XT is a better block than the GTZ. The naming is weird but the XT is the newest one out.
I was just doing some benches at 4.5ghz, might have been able to boot with lower vcore but I'm lazy so just cranked it up for the runs
You should get 4.2Ghz pretty easily with decent temps, I was running 4.2 the other day with around 1.36v, I doubt it was stable as I need about 1.35v for 4ghz stable. Most people I've seen need less vcore than me though
Oh and, scores on the AM3 run covered so mike can't see
Temps running LinX here too, general use gaming etc is a lot lower.
No that's my mistake I was thinking of the old GT, my mind must have been somewhere else!
Thanks for the info here, this kind of stuff is exactly what I'm looking for! Now, I was under the impression that you couldn't use the 21x multi on the i5 constantly, but I notice in your first SS you have it clocked at 200x21. What is the deal with this, can you run the 21x multi constantly or not?
I'm pretty much cemented on an i5 now assuming I can find the proper backplate for my GTZ... Post in this thread if you know where to get one!
^^ Yup I think all boards allow you to run the 21x multi, you just have to enable turbo
As for the backplate for your GTZ, contact swiftech, I've heard they are pretty good with support and would maybe send you one out for free..
Here is a temp log of when I had my GTZ. I was gonna do a comparison between it and the XT, but killed my mb before I got to power on the computer with the XT. After I got the new one, I was never in the mood to do a comparison, and ambients were probably not going to be the same. I also don't think that I have a good seat on the XT.
The average at the bottom isn't a complete average, it's just an average of a section that was all 100% load. This is while running LinX.
For support, contact [email protected] She replies quick and took care of me when I needed the 1156 backplate for my XT.
Thanks a lot for the post Mikecdm! It's interesting to see that you were temp limited right around 4.2, which is my main goal for an i5 upgrade. Though, since this was linx, I assume that you probably would have felt comfortable with slightly higher temps.
I talked to Gabe at swifty through e-mail, and he told me the same thing, contact Michelle during the week.
1 - 13 of 13 Posts
