I'm using the Lian li Galahad 240 water cooling.What cooler are you using?
depending on air or liquid what thermal paste did you use and how much?
How is the pump and rad mounted? What orientation? Could air be getting trapped in pump if it is the highest point in the system? How loud is the pump and do you hear any whirring or bubbling noises?I'm using the Lian li Galahad 240 water cooling.
