Hi all,
I am using a full costum loop using a EKWB Quantum Velocity-2 LGA 1700 water block.
So ive done some testing with Intel XTU some results with Cinebench32 multicore test:
PL1-253w_PL2-253w
Water temp = 23c
Stock core voltage offset = 83c is this a good temp? This is with Intel FULL official power of 253 watts.
Undervolt: 0.050v = 76c
Undervolt: 0.065v = 75c
Undervolt: 0.100v = 72c = a drop of 11c not bad at all.
So i will go down further to see more improvements in temps as long as it doesn't crash of course.
But question is i have to change the core voltage offset in the BIOS for the Asrock mb. That i understand in order to do so i have to choose option adaptive mode to change offset voltage otherwise i won't see the option, but do i need to change more settings? Just want a simple safe solution. Normally i keep it at stock settings on my previous rigs this time this i7-13700k is a hot head and yes my FIRST time undervolting please bare with me Now a -0.100v is safe correct? I did read that going lower might be stable at 100% loads but not stable at low loads or idle ie crashes correct?
So in short after im sure any off set voltage im happy with is stable all i need to change in BIOS is applying that off set voltage in BIOS without changing other settings correct?
Thanks in advance.
PL1-253w_PL2-253w
Water temp = 23c
Thanks in advance.
