Hi,
Well given no one replied yet to my previous question about undervolting PLL I went ahead and played around with that, the multiplier and the VCORE. Here's some of my findings.
My BIOS only allows certain specific voltages to be set, that aren't .005v apart, for PLL voltage, e.g. 1.715v, 1.753v, 1.80xv and so on, or auto.
Initially I tested my previous stable setup with a PLL voltage of 1.715v of the following:
- VCORE: 1.365v
- Multiplier: 45x
- BCLK: 100.2MHz
The above was stable, I didn't do an extensive stress test though. Most of my tests initially are 30-45 minutes, custom settings using up 3/4 of my memory, on Prime95.
I then tried the following with the same PLL voltage:
- VCORE: 1.365v
- Multiplier: 46x
- BCLK: 100.2MHz
Sadly the above crashed about 5 minutes into the test.
Since that I've managed to decrease my initial VCORE voltage from 1.365v to 1.350v and remain stable using the PLL voltage of 1.715v. Unfortunately a VCORE of 1.345v crashed about 7 minutes into the test. I will run an extensive test today and see what it turns up.
My temperatures are at most 73C on a Corsair H70 using AS5. They average around 65-70C after 15 minutes in the test.
Any suggestions or feedback are welcome.
- VCORE: 1.365v
- Multiplier: 45x
- BCLK: 100.2MHz
- VCORE: 1.365v
- Multiplier: 46x
- BCLK: 100.2MHz
