Hello all:
I am nowhere near to overclocking in general or quad cores (been overclocking since the Q6600). I don't say this to brag but merely to demonstrate I know the drill: every CPU is different, requires different voltages, some OC higher than others, etc etc.
With that being said, I know the vCore is much more important to Ivy Bridge chips and most cpu's for that matter, but my question is this: What is a good starting point for the cpu i/o voltage and what is the max safe voltage for the cpu i/o voltage setting? Or do you guys leave your cpu i/o voltage setting at AUTO (probably unlikely but doesn't hurt to ask)?
As a point of reference I am currently running 4.5Ghz with 1.225 vCore and CPU I/O Voltage at 1.19 seemingly stable with a Corsair H80 and 2 Gentle Typhoons AP-30's 4250RPM idle temps are 23-31 celcius & load temps are 45-60 celcius.
Also should I disable EIST (speed step) and overspeed protection? Do these effect stability at all? I currently have them enabled but notice my core speed is always locked at 4.5Ghz anyway so I might as well disable these two settings?
Thank you all very much in advance for your input it's good to be back haven't posted in some time
Merry Christmas!
Merry Christmas!
