He looks to be running it on stock, as can be seen from the throttle CPU frequency @ 1600MHz.
It can still idle down to 1600 even when overclocked.
Exactly this. Set your BCLK to 100.00 and set everything else to default. Use the "Load Optimized Defaults" option in your BIOS. I'd be willing to bet that your chip is overheating and throttling. His CPU frequency is at 1600mhz because of the why his C states are configured. It doesn't mean his multi is at the stock setting. Disable any auto oc utilities you may have open as well.Originally Posted by Forceman
That is a very high voltage, and also a pretty high BCLK. I would reset everything to default, and then try overclocking it using manual voltages and just the turbo multiplier. I'm guessing you used some form of auto-overclocking (either BIOS or software) which sometimes causes less than ideal results.
I have to admit I did use the EasyTune software that came with my motherboard at some point which may of effected as you say. I'll load the optimized defaults and post back shortly.Originally Posted by King Who Dat
There's no way you should be seeing 1.45v using stock settings. What are your cpu temps like ?
Like I said 10 posts ago, the chip is downclocking due to the way his C states are configured.
Not how I personally have mine overclocked. Thanks for the reality check.Originally Posted by Forceman
Not sure what you are saying. It is completely normal for the chip to downclock to 1600 when it is idle as long as the power saving features are enabled in the BIOS. If you disable all the power saving then it might stay at the higher freq all the time (depending on the motherboard) but just because it is at 1600 doesn't mean anything is abnormal.
