So I'm at 4500Mhz (45x100) vcore 1.275 which ran Prime95 for 5 hours (temps around 80, highest was 87 after 1½ hour) without any problems last night, at lower vcore 1.270 I got errors saying: "FATAL ERROR: Rounding was 0.5, expected less than 0.4"
I tested with OCCT this morning and it ran for 12min, then giving me an error detected and a bunch of graphs which I couldn't really see anything from.
I ran it again an got error after 3 min.
Should I just up the Vcore to 1.280 or is there anything else i should be setting like VSA & VCCIO voltages?
I am running my ram with the XMP profile.
I have PLL Voltage On and set to high.
Guides say I should disable Turbo boost but when I do that my cpu won't OC.
I tried 46x100 earlier but that wasn't even stable at 1.35v and the temps were over 90!
I am using the L.N.A on my NH-D14 SE2011 as all my other fans are tuned for low noise.
Thank you for any input, I am new to this game and followed the text and video-guides from this site.
