Please give your advice and let me know why you choose your opinion. It would be most appreciated. Resolution = 1920x1080, games = BF:badcompany2, MW:2, H.A.W.X. Whatever else badass games come out.
And yes, i know I listed the i7-860 for $129.99, that is the price I am getting it for from intel retail edge
At the moment I am debating whether to spend the extra $130 and get a HD5850 so in a year or two I can do crossfireX HD5850, or whether a single hd5770 will suffice until I go crossfireX 5770... Gah! lol, i AM on a budget. Broke college student.
as far as the case goes, I already purchased a Lian Li PC-K62.
Btw, ive sat here the last 45 minutes looking at benchmarks between 8 games at 1920x1080 on max settings between the hd5850 and the hd5770 and recorded the fps between the two to find out the percentage increase in terms of performance, and then did the same with the 3Dmark vantage score and averaged out the 9 percentages. The HD5850 has a 40.4% increase in performance over the HD5770, though.. it also has a 72% price increase. You can weigh your options on if the price increase is worth 40% more performance or not.. I think I might go for it though.
1 GIGABYTE GA-P55-UD4P LGA 1156 Intel P55 ATX Intel Motherboard - Retail Model #:GA-P55-UD4P Item #:N82E16813128400 $169.99 http://www.newegg.com/Product/Produc...82E16813128400 1 Intel Core i7-860 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Processor Model BX80605I7860 - Retail Model #:BX80605I7860 Item #:N82E16819115214 $129.99 1 CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail Model #:CMPSU-850TX Item #:N82E16817139009 $139.99 http://www.newegg.com/Product/Produc...82E16817139009 1 G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail Model #:F3-10666CL7D-4GBRH Item #:N82E16820231276 $99.99 http://www.newegg.com/Product/Produc...82E16820231276 1 Sony Optiarc DVD Burner with LightScribe Black SATA Model AD-7241S-0B LightScribe Support - OEM Model #:AD-7241S-0B Item #:N82E16827118032 $33.99 http://www.newegg.com/Product/Produc...82E16827118032 1 Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive Model #:ST3500418AS Item #:N82E16822148395 $49.99 http://www.newegg.com/Product/Produc...82E16822148395 1 ARCTIC COOLING MX-2 Thermal Compound - Retail Model #:MX-2R Item #:N82E16835186020 $7.98 http://www.newegg.com/Product/Produc...82E16835186020 1 XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail Model #:HDT-S1283 Item #:N82E16835233003 $39.91 http://www.newegg.com/Product/Produc...82E16835233003 1 XIGMATEK ACK-I5361 Intel Core i7/Core i5 compatible Bracket Set - Retail Model #:ACK-I5361 Item #:N82E16835233038 $7.99 http://www.newegg.com/Product/Produc...82E16835233038 1 SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail Model #:100283L Item #:N82E16814102858 $179.99 http://www.newegg.com/Product/Produc...82E16814102858 Subtotal: $859.81 after mail in rebates: $829.81 |
